heavily scratched t top help
Old Mar 23, 2014 | 03:19 PM
dexyman's Avatar
Car: 1991 transam
Engine: 305 tpi
Transmission: t5
both my t tops have lots of scratches on them
can these be refurbed or replacement available.
no idea how they have got like this (they were like this when i bought the car)
really looks crap.
considering rubbing them down and spray painting them black to tidy it up
any other ideas would be nice
Old Mar 23, 2014 | 04:08 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: heavily scratched t top help
this may help....https://www.thirdgen.org/forums/auto...-you-wont.html
Old Mar 23, 2014 | 06:36 PM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
zenish I was just about to post that same link. +1
Old Mar 25, 2014 | 07:18 AM
dexyman's Avatar
Car: 1991 transam
Engine: 305 tpi
Transmission: t5
upon closer inspection its not scratches it looks like hundreds of little cracks .
not deep though .
i assume these roofs have a sprayed on tint applied to them .
looks like that is all cracking
can this be removed and reapplied
think i may just colour code the roof but unsure if it will look ok
Old Mar 25, 2014 | 07:24 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
These are the lexan pieces, yes? Earlier models got glass roofs.
The cracking and crazing is in the lexan , not much you can do about it except paint them.
Many people replace the lexan with the glass ones. Direct fit replacement.
Old Mar 25, 2014 | 07:31 AM
dexyman's Avatar
Car: 1991 transam
Engine: 305 tpi
Transmission: t5
yup lexan tops
Old Mar 25, 2014 | 08:25 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
IF the polishing them back out doesn't work, I sanded mine down with 1000 grit and then used Sems trim paint on them. They match the headlight buckets perfectly, are easily touched up, and look great!
Old Mar 25, 2014 | 06:35 PM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Since thee are the lezan ones you could sand the scratches out with finer and finer grit sandpaper then polished them out, or forget the polish and clear coat them with a UV protectent paint
Old Mar 26, 2014 | 06:41 AM
stealtht/a's Avatar
He said they aren't just scratched, started crazing too. Can't sand that out. Personally I'd junk them and get glass ones, but otherwise paint them body color. Prob have to do both sides .
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
