Help wipers!
Car: 82' Z28 Crossfire
Transmission: Turbo 350
Help wipers!
I just replaced my wiper motor on my 82 camaro, and I'm still facing the same problem. My driver side blade is sweeping too far onto my pillar. My blades keep breaking and is becoming an expensive problem. I've tried the adjustment under the cowl and all it does is adjust park. How can I adjust sweep, please help
Car: 1986 IROC-Z
Engine: 5.0 4bbl
Transmission: 700-r4
Axle/Gears: 2.73 G80
Re: Help wipers!
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Help wipers!
Is there any looseness/play in the linkages? Or perhaps the wrong length of wiper blade on the car?
Re: Help wipers!
There is a little play in linkage, maybe motor too, but brand new motor. I've thought about length of blades. And I think I have another linkage.. I can try installing new one?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Help wipers!
Turn wipers off,remove the wiper arm and relocate it to the proper seat.
Re: Help wipers!
What do you mean by relocate? If you mean "move back a couple of splines" that does not work on my setup. I have notches where wipers HAVE to be. Only adjustment is is right where motor hooks to arms
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Manta..the driver side only goes on one way..no way to get it out of place..sounds like the blades are too long or the arm itself is bent..blade should be 18 inches I believe..if it is the right length,inspect your wiper arm and see if it's bent anywhere and either bend it back where it should be or replace it.
Re: Help wipers!
Engine: 5.0 EFI
1Aauto
Sponsored Vendors
Sep 23, 2015 01:09 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 01:00 PM
