Painting inner fender liners and headlight trim
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
I was wondering what you guys think of what I should paint the inner fenders. I don't have a lot of money and figured going with something like Duplicolor bedliner spray would be a good idea. http://www.summitracing.com/parts/shw-tr250
And I also was wondering what color you firebird guys would paint the headlight fairings and turn signal housings? I was thinking semi-gloss would be good. pic of what I'm talking about:
http://i1242.photobucket.com/albums/...7-5-201301.jpg
(yes that pic is from motobooks' TTA resto, he's awesome. check out his threads)
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Painting inner fender liners and headlight trim
You talking about the wheel wells or under the hood.??
Use SEM trim black for the headlight trim. Make sure you clean it well and use an adhesion promoter.
The wheel wells and fender liners.
Thanks, I needed some SEM interior paint too, so I ordered them together. Will Bullydog adhesion promoter work? I have some left over from when I dyed my interior.
Anybody know if the bedliner is a good choice?
Engine: 5.0 EFI
I don't know about bed liner,I used 3M undercoating,it has the lumps and bumps like the original undercoating the Dealer used.
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
Yes, Bulldog Adhesion Promoter is fine.
I like RustOlem semi-gloss in the quart can for the under carriage. You can get it for about 9 dollars a quart from Walmart, You can brush it on like POR15 and it'll lay out nice, or you can thin it with 5-10% mineral spirits and spray it through a gun.
Car: 85 Camaro
Engine: 1976 350 4 BOLT MAINS
Transmission: T5 NWC
mineral spirits can slow dry times considerably(higher chance for runs). Xylene and naptha work good, you can find xylene at most local paint shops.
Thanks for the suggestions, I may try the Rustoleum semi-gloss stuff. Is it better to brush it on or spray it?
Car: 1990 Trans Am
Axle/Gears: Stock
Are you thinking along these lines of painting the headlight bezels?
https://www.thirdgen.org/forums/memb...ml#post5802905
And I just found out that my turn signal housings have a lot of white over spray from an earlier respray (before I got it) on the orange lenses. One tab on each housing is also broken, so I'll need to get some new ones. It seems like a waste to refinish broken pieces.
Car: 1990 Trans Am
Axle/Gears: Stock
I guess SEM paints are great, since everyone's talking about them.
Wish I could get them here.
Thanks, Transaero! Still got a lot of work to do... and so little time to do it all.
One of my turn signal housings is cracked as well. Depending on the parts that are broken, you may be able to use some JBweld or similar to fix that.
To get rid of the overspray, just try some 1500 or 2500 grit sanding paper and give the lense a rub, then polish it up
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
