how about that under body????
Old Apr 11, 2015 | 05:05 AM
mhatfield 14's Avatar
Car: 87 trans am
Like I said in a previous post im re doing my firebird trans am and want to underbody it, and was thinking maybe using bed liner? What does everyone else use and how did u apply it
Old Apr 11, 2015 | 06:34 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: how about that under body????
How rough is the underside of your car?
Personally I like the factory grey e-coat with body color overspray.
Old Apr 11, 2015 | 08:10 AM
Car: 87 trans am
I wouldn't say its to bad, just wanna preserve it, Michigan weather sucks
Old Apr 11, 2015 | 11:50 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I'm with you, PurelyPMD.
The question for me is, what have people found that nicely replicates the e-coat? It's sort of an unusual shade of grey, with a unique gloss level.
Old Apr 24, 2015 | 10:31 PM
tgarcia76513's Avatar
Rubberized undercoating. Not to expensive and leaves a clean look. Its job is to protect ur car and is a pita to take off so i know it does a good job. Just keep it off the paint.
Old Apr 25, 2015 | 08:18 AM
cheesehomer's Avatar
Car: 1987 Iroc Vert
Transmission: 5 spd
Before
I sandblasted my floors, then applied epoxy primer, topped with Urethane single stage paint (3 coats of each) from Eastwood. After final assembly I will apply a clear coat of oil base undercoating.
Old Apr 25, 2015 | 09:22 AM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
That looks pristine! Very nice job. Does the "clear" undercoat actually protect and dampen road noise like asphalt undercoat. Is it sort of like what you see on the lower body sides of high end vehicles?
Old Apr 25, 2015 | 06:44 PM
Car: 1987 Iroc Vert
Transmission: 5 spd
Por15 on the rockers
Por15 on A-arms and spindles
Thanks, I don't think it will dampen road noise, but will protect against corrosion and moisture. The car hasn't been on the road yet, but I will be putting Aluminum foil Sound Deadener on the inside floors and doors. I went to replace the all the bushings, front and rear with ball joints and decided, If Iam going to go that far, I might as well try and see if I can make the floors look as good as the rest of the car will when it is painted. Its a 1987 5spd vert.
I go to car shows all the time and say to myself, SELF !.... Why can't I get this same look without paying big bucks, and with a little work you can.
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Kenwood
Sep 4, 2015 05:50 PM
