headliner replace
Old Dec 20, 2001 | 03:12 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
headliner replace
has anyone ever replaced the headliner in there car? where is a good place to get a replacement and how much should i expect the cost to be? how much work is invloved?
Old Dec 20, 2001 | 08:42 AM
Apone's Avatar
Car: 1991 GTA
Not that hard actually....
I recently did this on my car. The hardest part will be prep time.
Make sure you take your time and take care of any rust. I simply sanded down any rusty spots and painted over them with Rustoleum.
You can get the replacemnt headliners from Classic Industries, Year One and the advertisers at the top of this page.
My car is t-top, so for mine all I had to do was remove the rear view mirror, remove both sun visors, remove the center dome light and both sail panels, and also the rear plastic piece towards the back of the car (it is the piece that covers the area where the headliner and hatch glass meet). After these pieces are removed, the headliner wil come right out, and then you can put the new one in. You will jsut need a second set of hands to support the back of the headliner while you install the front.
Good luck!
Old Dec 20, 2001 | 09:42 AM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
Depends
I removed my headliner and repaired it myself... I used fiberglass resin and fiberglass cloth on the back of the headliner. Cost me like $10.00 and about 2 hours of work (that included removing the headliner from the car). I was going to replace the material on the headliner myself but I am not that handy with material and sissor's so I brough the whole headliner to a local "Autobody/Glass Repair" shop and they re-did it for $100.00 (this is Canadian funds) with new gray material.
So if you are good with material and your backing board isn't too far gone you can fix it like new for probably $40.00 (materials included).
There is a Tech Article on that whole procedure.
Old Dec 20, 2001 | 10:41 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I was told by an upholster & it works great, once you get the headliner material off the back board, to take a wire brush, & scrub off the rest of the foam to get all of the foam off.
worked great...I said that...
John
Old Dec 20, 2001 | 10:54 AM
dilligaf's Avatar
https://www.thirdgen.org/newdesign/t...errepair.shtml
this should do it for you
Old Dec 20, 2001 | 05:00 PM
Z28DJP1987's Avatar
Check your Yellow Pages for a Auto upholestery shop. I had mine done in the original color & material for about $160. This was for a factory appearance installation. Now you can DIY or buy that one piece junk and it will look like ?????. Your choice.
Old Dec 20, 2001 | 05:08 PM
labrat's Avatar
Car: 87 IROC-Z
Transmission: automatic
I had mine done by an upolstery shop. it cost $140. The car was non-t-top.
Old Dec 20, 2001 | 06:28 PM
loomdog32's Avatar
Car: 82 Camaro Z28
i cant believe i somehow missed the tech article on the headliner.. i guess im startin to act more like a blone since i died my hair so i didnt look like a blone. as soon as i get the engine work done and get the car back home (hopefully mon xmas eve ). i could probably just have my mom cut and apply the fabric for me. she does all that craft c r a p. sometime within the next 2 weeks i should be postin some pics of the '83. that should give me enough time to get it running and smoged and some mods on it ..
Old Dec 20, 2001 | 06:38 PM
87ROCZ's Avatar
Oh to live where there is no snow
My Iroc is all tucked in under a car cover in a warehouse.. Been there since the first week of October!! I am in a bad way for a V8 rush!!!! My winter beater '90 S10 is just that...a winter beater ... but I can smoke the tires in 1st and 2nd!! hahahaha...5 speeds rule!! Blah!! Is it Spring yet????
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
diana227vegas
Jul 8, 2016 12:27 AM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
