Spolier Nuts
Old Nov 15, 2015 | 08:07 PM
FormerL69's Avatar
Car: 1982 Camaro Pace Car
Engine: LU5 Crossfire
Spolier Nuts
I'm reattaching my rear spoiler after paint and am wondering about the attachment nuts and body sealing.
The parts & assembly manual shows a washer (p/n 2134885, WASHER-HTR) but my car (an '82) didn't have these when I disassembled it. I assume there should be a gasket of some kind installed since not having one could easily let water get in to the decklid.
Couple of questions:
First, does anyone know what the "HTR" designation means for p/n 2134885? "Heater" comes to mind and I suppose that makes some sense. Not a big deal -- but I am curious.
Second, does anyone know if there really should be a rubber washer installed or if the 10mm nut was the type that had pre-applied sealer on it? If there should be a separate washer, is it just a regular old rubber washer? The GM part number is no longer available and I can't find any pictures of it.
I know I'm overthinking this and that there needs to be a gasket/washer/sealer installed to prevent water intrusion.
Given that my car is an April '82 build it's possible the washer was added later, but the parts & assembly manual does show it for the 82 model year.
Anyone have any insight?
Old Nov 16, 2015 | 08:42 AM
J-money's Avatar
Car: 92 RS camaro, 99 Z-24 cavalier
Engine: 5.0L TBI, 2.4L
Re: Spolier Nuts
I just took my spoiler off my 92 rs last week and was wondering the exact same thing. Mine didnt really have a gasket though. It looked like there was some sort of sealant used though. What ever it was after all these years it was still rubbery and not brittle.
It looked as if there was a generous amount on mine because it was enough that some of the nuts were almost covered in the sealant. I couldnt find anything about any washers so I just used some sealant I picked up at the local advance and applied a generous amount onto spoiler studs then re-installed it.
Old Nov 16, 2015 | 05:10 PM
FormerL69's Avatar
Re: Spolier Nuts
Thanks. Looking closer at the book, it looks like the Firebird spoilers may have used a gasket between the stands and the decklid.
What you described is what I think my car had -- the nut flange had sealer applied to keep water out and there was no washer ever installed. The book doesn't list the sealer or that the nut should have sealer applied. The exact name is:
NUT - HEX W/CON WA (M6X1) PEOR
I assume this translates to Hex, with connecting washer (M6 x 1).
Not sure what "PEOR" means.
Anyone else?
Old Nov 16, 2015 | 06:54 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Spolier Nuts
I used nylon and rubber washers between the wing posts and deck lid to keep the two from touching. I did not want to scratch up my new paint with direct contact. You can just barley see a crack of light between the two using a flash light at night.
Old Nov 16, 2015 | 07:29 PM
aroto's Avatar
Car: 1984 Camaro Berlinetta
Re: Spolier Nuts
I removed and reinstalled mine. On the existing nut was something exactly like grey plumbers putty. It comes in a strip rolled up. its used to keep water from getting inside the hatch panel.
Old Nov 16, 2015 | 09:34 PM
FormerL69's Avatar
Re: Spolier Nuts
@ Ron U.S.M.C and @aroto -- Thanks for the info guys!
Old Nov 16, 2015 | 11:33 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Spolier Nuts
I can't speak specifically to your Bird, but a non-hardening butyl sealant was used by GM on some applications like that. It "never" fully cures, and does a good job preventing leaks into body panels where studs go down through them.
Old Nov 16, 2015 | 11:53 PM
J-money's Avatar
Re: Spolier Nuts
That sounds exactly like what was on mine. I just went with one of the permatex sealers that is non hardening. Figured that would be close to what GM had on there.
Old Nov 17, 2015 | 08:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Spolier Nuts
It's been some years, but IIRC, I used the following. The 3M product will work as well (make a little ball of it and smash it flat and you have a washer).
JamesC
Attached Thumbnails Spolier Nuts-screen-shot-2015-11   Spolier Nuts-img_3726.jpg
Old Nov 17, 2015 | 06:58 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Spolier Nuts
Folks can even look for a similar sealer called "dum-dum" for preventing
leaks/paint chafing on screw/stud reassembly................
Comes in strips and colors or in bulk cans.
http://www.proformproducts.com/en/pr...m-strip-caulk/
Old Nov 17, 2015 | 10:43 PM
FormerL69's Avatar
Re: Spolier Nuts
@JamesC - I actually bought the 3M strip caulk a while back and originally planned to use that. As I started looking at the book it got wondering if the original GM nuts with the sealer already applied were still available or not.
Thanks again for the info everyone.
Old Nov 28, 2015 | 09:51 PM
B4C5.7's Avatar
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Re: Spolier Nuts
Autozone carries strip caulk in a roll, have used it effectively to install spoilers and hatch lid to glass. Reasonable cost.
Stroopwafel
Nov 5, 2015 03:45 PM
TheSwarm666X
Oct 26, 2015 03:29 PM
MrMac98
Oct 21, 2015 05:12 PM
TheSwarm666X
Oct 18, 2015 10:12 PM
nickdiesel
Oct 17, 2015 02:42 PM
