T56 swap now what rear gears??
1990 gta L98 now with T56 LT1 style..
I have 3.23gears now but not right for the T56, so 3.42/3.73/4.10 are my choices..
I am leaning to 3.73 so I can actually use 6th gear.
My driving is to car shows and longer drives.. no autocross or 1/4 mile.
any one actually have experience in this area.?
thoughts??
thanks
Mike
thoughts??
thanks
Mike
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Car: 1992 Trans Am
Engine: 6.0 LQ4
Transmission: T56 Magnum F
Re: T56 swap now what rear gears??
I did the T56 swap a few months ago and I went with 3.73s. I'm loving them. In my old Formula I had 4.10s behind a T56 and the were great for drag racing, but a little much for cruising. 3.73s have my vote.
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
i have 3.73 and wish i went 4.11. i have a 27in tall tire instead of the stock 26in, i need some more gear
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i have 3.90 and have plenty left in 6th gear and cruising at 80 at 1800 rpm
OK sounds like 3.90 would be ideal-
however- I have a 10 bolt so back to 3.73 vs 4.10.
I have 245-50/16 stock height tires.
I am leaning toward 3.73.
Car: `86 SS / `87 SS
It is. And Summit lists two different sets of Motive 3.90 gears for the 7.5" 10 bolt.
Before you order, you might also want to make sure your T56 isn't a 1993 version.
see why I come here, did not realize 3.90 was an option
3.90 seems to be the right choice for me.
trans was from 1996 Camaro so it is .5 OD
thanks
thanks
boardwell
Sep 4, 2017 09:00 AM
TransAm12sec
Feb 16, 2016 06:48 PM
3.8TransAM
Oct 1, 2015 07:47 PM
