Hey guys! Can i see your guy's sweet engine bays?
Old 12-02-2015, 08:24 PM
90formulaVortec's Avatar
I'm 15 and sorta restomoding my 90 firebird and I'm dropping in a 355 i built and I want some ideas for how to do my engine bay So show me what you guys got!
Old 12-03-2015, 06:40 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Hey guys! Can i see your guy's sweet engine bays?
Could you do us a favor and fill this out .It helps us answer some of your questions. This way with just a glance we know what you’re working with. If you don't know just put "stock" and we can help you figure it out.
Simply click on the blue stripe where it says "USER CP" near the top of the page.
then
EDIT YOUR DETAILS
then fill in the last 4 lines at the bottom of the page.
Car =
Engine =
Transmission =
Axle/Gears =
Anyway here's what I did with my TBI.
I went with the "Open Air Element" and "Extra Flow" filter top to take advantage of the 2in. Steel Cowl hood I put on.
Nothing "Spectacular" but considering how it looked when I bought it, it looks pretty good.
Old 12-03-2015, 06:44 PM
then
EDIT YOUR DETAILS
Car =
Engine =
Transmission =
Axle/Gears =
Alright sorry didn't know super noon to these forums thanks
Old 12-03-2015, 08:17 PM
Engine: TBI,5.0
I think cap and plug wires can dress up a bay allot.
Some come in red, blue , yellow and of course black.
Old 12-06-2015, 09:23 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I'm probably doing more of an extreme version than your'e looking to do but you might like to follow my build thread along.
https://www.thirdgen.org/forums/memb...oming-aka.html This is a picture of the latest:
The best way to clean up the engine bay with limited funds is to take your time, do one piece at a time and thoroughly degrease/clean/respray/replace every visible part. Start with the easy stuff like plug wires and radiator hoses. Replace or really clean the fluid reservoirs. The pullies you can remove and respray black. The cast aluminum brackets can be removed and get a quick soda blasting to look brand new. Intake can be sprayed black after cleaning. If the paint in the engine bay is iffy you can buy the same color in rattle can and respray--a few threads on her of guys doing this with good results.
Old 04-13-2016, 06:13 PM
8996chevy's Avatar
Car: 89 IROC
Engine: 355,LT4 HotCam,E-tec, vortec int.
Transmission: 5 sp., Alum Driveshaft
Axle/Gears: 3.73 Posi
here's my 89 iroc
Attached Thumbnails Hey guys! Can i see your guy's sweet engine bays?-100_4568a.jpg   Hey guys! Can i see your guy's sweet engine bays?-100_4565.jpg   Hey guys! Can i see your guy's sweet engine bays?-100_4563a.jpg   Hey guys! Can i see your guy's sweet engine bays?-100_3979a.jpg
Old 04-13-2016, 06:32 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
By the way, if you're just looking for as many pics as possible you can put 'engine bay site:thirdgen.org' into google images and have as many pics as your heart desires. Won't get you them grouped by car or with the helpful tips though, so there's still value to a thread.
Old 04-14-2016, 04:38 AM
Engine: TBI,5.0
8996chevy,
That's one bad a-- ride.
Old 04-14-2016, 05:31 PM
craptrman's Avatar
Car: 1988 Iroc-Z
Transmission: 5-Speed
Axle/Gears: 3.45
Here is a couple of mine.
Old 04-14-2016, 09:17 PM
section 8's Avatar
Car: 1988 Camaro iroc-z
Engine: 350 stock engine
Transmission: stock automatic
Axle/Gears: stock
That has to be one of the cleanest if not the cleanest engine bay ive ever seen.
Old 04-14-2016, 09:43 PM
FBFAN's Avatar
Car: 91 Firebird
Engine: V-6
That's 100% pure awesomeness!!
Old 04-15-2016, 07:15 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Old 04-15-2016, 09:58 AM
skip91's Avatar
Car: '91 RS, '64 C10 Stepside
Engine: 305 TBI, '00 5.3
Transmission: Manual, Automatic
Axle/Gears: 4th Gen with 3.42, 4.10
Did you guys get new overflow and reservoir tanks or clean your original ones. Like most engine bays on here, my two tanks have simply gotten dirty looking with age.
Old 04-15-2016, 10:40 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Another option that may interest you is using a fourth gen washer and coolant setup. They end up under the battery or in front of the radiator. Sometimes the plastic gets stained and it's a waste of time to clean-that is why I originally removed mine.
Old 04-15-2016, 10:44 AM
TkernIROC1986's Avatar
Car: 1986 IROC-Z
Engine: 5.7L TPI L98 350
Transmission: 700R4 Auto
Axle/Gears: 10-Bolt Posi Disc 3.73s
Here's my engine bay, 86 IROC, 350 L98 TPI, all "stock" looking...
Old 05-04-2016, 05:34 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Heres mine still in progress
Old 05-04-2016, 05:56 PM
84TA327's Avatar
Car: 1984 Trans Am
Engine: .040 over 327, aluminium heads
Axle/Gears: 4:56s auburn posi, mosers
Old 05-06-2016, 11:35 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Here's mine
Old 05-07-2016, 09:03 AM
Dueling73s's Avatar
Car: 73RS, 85 Iroc, 11 GT
Engine: 383FI, 406 FI, 5.0
Transmission: TKX, TKO600
Axle/Gears: 10 Bolt 3.73s, Strange 12 bolt 3.73
Still Work in progress L69 car to Fuel Injected 406
Old 05-07-2016, 03:38 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Old 05-11-2016, 11:26 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Sweet!
Would you share with us what you did for duct work to attached to the L69 air cleaner? The adapters at the snorkel, the flex tubes, etc? Were you able to attach to the original ducts at the core support?
Old 05-11-2016, 01:07 PM
Dueling73s's Avatar
Sweet!
Thanks Dyno, I was trying to be similar to stock but different. I used 2nd Gen Trans Am adapters with 4 inch flex hose with expandable sleeve over it and ran it out the inner fender. This is only pic I have right now
sorry it is without air cleaner.
Old 05-11-2016, 02:03 PM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Old 05-11-2016, 02:08 PM
shayapaula's Avatar
Car: 84 camaro z28 H.O
Engine: 305 H.O
Transmission: world class T5
Axle/Gears: 3.73 limited slip
Not the best photo in the world but shes pretty clean looking
Old 05-25-2016, 03:58 AM
skip91's Avatar
Found this on my local Craigslist. Is this both a reservoir and overflow tank? Difficult to modify and/or install? Will the current pump I have on my stock reservoir work?
Old 05-25-2016, 11:49 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Resevoir, do a search.Been done a dozen times, did mine over 10 yrs ago.
Old 05-25-2016, 12:12 PM
Twin_Turbo's Avatar
Old 05-25-2016, 12:25 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Damn!
Old 05-26-2016, 09:15 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Some sweet engine bays here!!! Makes me want to stop dragging my feet and pull my motor and do mine again...
MantyZ28
01-14-2016 05:41 PM
ledman66
12-14-2015 11:14 PM
Ellis87z28
12-02-2015 09:17 PM
camaroz1979
12-02-2015 08:19 PM
fordspanker
12-02-2015 11:31 AM
Quick Reply: Hey guys! Can i see your guy's sweet engine bays?
