What do these wires go to?
Old Dec 22, 2015 | 03:29 PM
sitheoriginal's Avatar
Car: 1987 Pontiac Firebird Formula
Engine: 5.0 TBI
Transmission: Stock
Axle/Gears: Stock
Found these wires disconnected on my 1987 formula 5.0. They are hanging on the bottom of the car beside the tranny. (700R4) anyway the connector has red/ black wires and the others are tan/black purple and light blue. The other end of the connector hooks into the transmission near the driveshaft (maybe speedo since it doesent work) the others head toward the engine bay? Anyone have a clue?
Old Dec 22, 2015 | 08:30 PM
Thornburg's Avatar
Car: 1985 Camaro Z28 IROC
Engine: 5.0L TPI H.O. 215HP STOCK
Axle/Gears: GU6=3.42
Re: What do these wires go to?
Somebody please chime in here, I'm wondering if his purple wire is the same as what I have coming out my firewall behind the brake booster wire harness...There has to be someone that has done a motorswap that knows what these wires are...
Old Dec 23, 2015 | 08:01 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Sith, It very well may be the VSS connector, not 100% on it though.Hard to say on the other three.Can you tell where they end on?
Thorn, yours could be the starter solenoid.Looks like someone just used a jumper to connect them.Remove the jumper & see if it wont crank.If so, could be somebody used it a crude starter disable.
Old Dec 23, 2015 | 08:58 PM
Thornburg's Avatar
Starter relay you say??? Now you have me wondering, I disconnected it while running and made no difference. I will have to check and see if the battery has enough juice to try and turn it over with it unplugged(waiting to replace in the spring).
How would the VSS effect his car if it was disconnected??
Old Dec 23, 2015 | 09:57 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Starter solenoid, disconnect it before starting.
VSS = vehicle speed sensor, it relays the proper signal to the speedo.
Old Dec 23, 2015 | 10:13 PM
Engine: 5.0 TBI
Transmission: Stock
Axle/Gears: Stock
They head back towards the engine bay.
Old Dec 24, 2015 | 11:20 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Without knowing where in the eng bay.Gonna be hard to say.
Old Dec 24, 2015 | 02:19 PM
Thornburg's Avatar
Thanks for the help everyone, after Christmas I am goin to try it, see what happens...
camaroz1979
Camaros Wanted
Dec 11, 2015 01:52 PM
Knight Prowl
Exterior Parts Wanted
Dec 7, 2015 10:40 PM
Showcase1186
Nov 23, 2015 11:04 AM
Jacques101
Nov 11, 2015 11:08 PM
thorflynn15
Nov 10, 2015 07:54 PM
