Need to tow car no front wheels
Car: 85 Z28
Engine: 327
We just got a 30 day notice to move. I have to move my camaro but have no front wheels. Car is pretty stripped down as I was in process of building. Is there any possibility of using a dolly or trailer without destroying bottom of it.
Car: 1991 GTA
Engine: LB9
Re: Need to tow car no front wheels
If nothing else, go to a wrecking yard and pick up a couple of wheels with tires. Something you could get for cheap for roller purposes would be S10 wheels, the bolt pattern is the same.
Car: 85 Z28
Engine: 327
I have everything. But it's down to bare bones. No breaks. Steering. Only has k member bolted in. A arms have no bushings.
Axle/Gears: 10 Bolt 2.73 Open
If you can find a sufficiently heavy duty furniture dolly...or two...this maybe?...
http://www.harborfreight.com/18-in-x...lly-61899.html
...and strap it/them with some heavy straps to your cradle...then MAYBE you could gingerly get this up onto a flat bed or roll back.
It's sketchy, but with the car stripped in front, and the weight down as a result, you might get away with it.
Car: 1983 Z28
Engine: Carbed 305
A boat ratchet winch mounted to the railing of any trailer will get it up there with the help of a person or two pushing and steering.
good luck!
Edit: Just remembered, no steering! lol Gonna have to ratchet it up there from behind with a come-along or boat ratchet winch
again, Good luck!
good luck!
again, Good luck!
I was assuming no way to mount from wheels. Sorry. Yes, the above from DonW makes the most sense.
Car: 86 Trans Am WS6
Engine: 383 stroker
id say try to find a wide dolly with large wheels, lift front of car onto it and make sure its on the frame only, use blocks as spacers, and then ratchet strap the frame to the cart nice and tight. this will be good enough to get it onto a flat bed.
Car: 85 Z28
Engine: 327
It won't be going far. And it's backed into garage so that part easy. I think maybe tow dolly best
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Whoboy580
Mar 4, 2016 07:10 PM
Irockthedrag
Feb 21, 2016 04:11 AM
