Dye or paint door panels?????
Old Dec 23, 2001 | 09:29 PM
89blackbird's Avatar
Can anyone tell me is it possible to dye or paint door panels. My door panels are 1989 GTA and are tan. I have changed my interrior to black and can not find Black door panels with the molded in arms.I have the flat style black with a cup holder but don't really like them. Is there anything I should clean them with before spraying them? thanks
Old Dec 23, 2001 | 09:45 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
I would clean them first, and dye them with Rit dye. You can get that dye really cheap at wal mart, costs about 1.50.
Old Dec 24, 2001 | 08:52 PM
These panels are vinyl and cloth.Will that dye work on Vinyl?????
Old Dec 25, 2001 | 02:22 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Let me know how it turns out. I'm interested as well.
Previous people have said to rough the plastic with some sandpaper and then throuroughly wash it. Then use a plastic adhesive aid and then spray. Do a search on painting interior panels.
When you get done I would appreciate any info you may gain.
Old Dec 27, 2001 | 04:12 AM
Blue502's Avatar
I've heard that if you use Rit Dye on fabric, you should use a salt water solution afterwards to set the dye. Don't know for sure if that is true or not, but you might want to ask at a fabric shop. If the Rit Dye doesn't work on the vinyl, get some vinyl dye in a spray bomb and use that. SEM brand works great (available at automotive paint stores).
How would you apply the Rit Dye? Via a squirt bottle? Can't see you putting your panels into your washing machine.
Maybe better to buy good black ones and sell your tan ones on eBay?
Old Dec 30, 2001 | 11:21 AM
RED IROC RACER's Avatar
i just painted mine gray worked fine jus make sure to clean off any oily stuff
Old Dec 30, 2001 | 05:14 PM
What did you paint them with????
Old Dec 30, 2001 | 05:38 PM
i dont know the exact name of the paint cuz my dad was the one who did it and he owns a body shop but its the same as normal car paint we use dupont and you have to add a additive to the paint so it will let the paint flex a little bit ask your local paint shop they can probably help you out w/the right additive you jus need to pick the color or find a color code from another camaro
if you give me a week or so il get a full list of materials for you from dupont
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
