BODY flex- how’s much too much?
Car: depends on the weather
Engine: several
Transmission: all manual
Axle/Gears: lots
Starting to go over my 88 vert. I put it on the lift to get a look under it better and my door jam gap opens up about 1/4-3/8”. Doors still open and close fine. Would this be considered normal flex or excessive? It doesn’t have any rust except for a small spot in the driver floor pan - vert top leak I am guessing.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: BODY flex- how’s much too much?
1/4 is a lot, let alone 3/8.Maybe thats "normal" for the verts, but regardless thats a bit much.Do you have any structural support added?
Engine: several
Axle/Gears: lots
No, all stock. Remember it is a t too car with the top bracing cut off.
My meaurement is a guess. Just sticking my finger in the door jam with it on the ground and on the lift.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Any flex is excessive, the sooner you remedy that the better.The closer you can get it to zero flex, the better.
Engine: several
Axle/Gears: lots
Subframe connectors were my first thought
need to get some real measurements and see how much it is really flexing
Car: '92 RS
Engine: 5.0TBI
Transmission: TKX
You don't really need to measure the flex for anything except curiosity. Just get all the chassis bracing you can get your hands on. SFC's, Wonder bar, etc.
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I added Spohn tubulars and they made a huge difference on my factory convertible which has a lot of bracing added by ASC already.
