Compressor set up
Old Oct 23, 2017 | 12:11 PM
Seattlehillmom's Avatar
Want a title? Post!
Compressor set up
We have a Craftsman 6 gallon compressor 150 max PSI. 2HP - 1HP. Delivery 3.7 scfm at 40 psi. Will the Devilbliss finish gun work with this compressor to spray BM Advance?
Old Oct 23, 2017 | 12:34 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Compressor set up
That compressor would only be enough for spraying a single coat on small panels. A front fender, Maybe a door, Maybe the front bumper. With smaller tanks the compressor will have to work much more often thus creating more problems with water in the tank or heating up the air in the tank. If the air in the tank is hot and there is much of a temperature difference between that and ambient temp you can get trace amounts of condensation on the panel.
soloc4
Dec 11, 2016 08:50 AM
factory89tpi
Sep 29, 2016 05:24 PM
RunawayRadio
Sep 18, 2016 10:28 PM
Ikes 91Z
Sep 18, 2016 06:45 PM
