87 Trans Am Cheap Resto
Old Nov 26, 2017 | 11:25 AM
F-body driver's Avatar
Car: 1987 Trans AM WS6
Transmission: TH700R4 Stock
Axle/Gears: 3.08 LSD
Hello Guys
That's my 87 Trans Am from Italy
The car was a bit rusted so I decided to do a cheap restoration
These are the pics
Paid 3.5k for the labour
Paint seems not good but is better than before for sure
Painted the floors with anti rust
New Trailing arms with poly bushings and new end links
done the whole floor tho
emptied cat
wheel well cleaned ant put some anti rust
new driver's side battery tray
bondo
holes closed because of previous owner anti theft system
bondo
under there there's a lil damage in the quarter panel but here we are in Italy so no replacement
new lips from metalfabrication
Old Nov 26, 2017 | 11:29 AM
Re: 87 Trans Am Cheap Resto
fender tabs rusted
patched kick panel's hole
new weatherstrips
Old Nov 26, 2017 | 11:32 AM
yeah it was a T5
Old Nov 26, 2017 | 11:50 AM
new used deluxe panels
repaired inspection cover
speed bleeders and new seals on the calipers
it looks good! New pads and rotors plus brake lines
want gta rims tho
new boot from a jeep on the intermediate shaft
new rag joint
sagging column fixed
energy trans mount
Old Nov 26, 2017 | 12:00 PM
Spectra tank and delphi sending unit, delco pulsator and delco fuel pump plus strainer
the best i can do with the spectra
testing new remy alternator and 21 lbs injectors from an IROC
looks good
Old Nov 26, 2017 | 09:13 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Looks Great!
Old Nov 26, 2017 | 11:00 PM
Black00SS's Avatar
Car: 1992 Trans Am
Looks really good! Nice car!
Old Nov 27, 2017 | 11:41 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Awesome, looks great. I especially like the driving pic with Italian street signs!
Old Nov 27, 2017 | 03:13 PM
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
great job. These cars are rare in Europe and either being locked away or being parted out (I was pleased to see a red Formula in Romania a few months ago!)
Glad to see one being restored to be driven
Old Nov 28, 2017 | 05:00 AM
Thank you guys!
Here in europe there are many v6 cars around and some GTAs
Formulas are more rare here
10 years ago I found an 87 T5 black car (pretty rare)
Italian streets are garbage for those cars but climate is good so they do not rust like crap
That's my car compared to some italians ones from the 80s
Old Nov 28, 2017 | 06:06 PM
Saxondale's Avatar
Car: 1984 Z28
Engine: 305 HO
Transmission: 5 Speed
Axle/Gears: 3.23 Truetrac; was better w/ 3.73
That car looks great. Your restoration is perfectly fine, particularly since you are in ITALY! Not a lot of parts cars for you to use, if any. Enjoy.
Old Nov 28, 2017 | 07:35 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Nice work F-body driver.
Old Nov 29, 2017 | 09:21 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
nice work!
Old Nov 30, 2017 | 08:29 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Good Job.
Old Dec 2, 2017 | 11:37 AM
Thank you guys!
Next step is front end rebuild and some HPs
Planned a LT4 hotcam swap and some head work for the extra lift
I've scored a full TPI setup from an 89 IROC converted to carb so I will port and gasket match it
I am planning on porting my 081 heads too in order to gain some cheap hp.
3.42s and I guess I will break mid 14s
Subframe connectors are a must
Old Dec 18, 2017 | 08:37 AM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
That thing looks great. I can tell you right now it would have cost you way more than that over here.
Old Dec 22, 2017 | 11:50 AM
turboguard's Avatar
Car: 1985 Pontiac Firebird Trans Am
Engine: 305 LG4
Transmission: 700R4 Automagic
Axle/Gears: No clue
Take care of those convex wheels, they are hard to come by!
Old Dec 22, 2017 | 09:33 PM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
Do the European folks like these cars or consider them trash? Here they are not accepted by a lot of muscle car guys because they are not old enough or a real muscle car. Funny thing is a late 80's Bird or Camaro could hang well in the 1/4 mile with a lot of so called muscle cars form the 60's and absolutely kill them in the twistys. Great job keeping her alive!
Old Dec 28, 2017 | 12:11 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Great resto, not cheap at all.Beautiful work.
Old Dec 28, 2017 | 12:46 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Well done.
What's sad is that those Italian cars are just as fast as that Trans Am is your pic lol...
Btw, how is the Syrian refugee problem over in your area? As bad as the RT media is implying?
- Rob
Old Dec 28, 2017 | 03:45 PM
those side italian cars are 39hp rated!
Our syrian refugees problem is getting bad. Too many here!
