1990 Camaro - factory front plate mounting question
Hi,I recently bought a very clean 1990 camaro rs. It's never had a front plate mounted on it,but it's required in California.
does anyone have a photo of the correct factory mounting assembly? How exactly does it mount to the black plastic grille? There are no holes there except where the grille mounts.
I have a plastic front mounting assembly from an earlier 80's camaro but it doesn't look correct for the car. I assume they changed the mounting assembly when they altered the grille
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: 1990 Camaro - factory front plate mounting question
I've got a couple of the front mounting plates and I think the screws also I'll sell for reasonable if you want. I'm in California too so shipping is not much. Get me your email address for pics and other info
Henry
Henry
Can you post a photo of it here? If it's the same as the one I have from an earlier 80's Camaro I don't need it. Also how does it mount to the grille? There are no holes for one in my black grille
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Does it say Z-28 between the two top holes? If so you probably have the right one. The holes are pretty hard to see
Drilling holes to mount a stupid front plate is painful, but at least it's not a Firebird, they get the holes drilled right into the front bumper cover.
So basically the plate holder gets screwed into the black plastic grille? There are no factory made mounting holes? Is there a template for it?
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
thanks for the info Drew. I have a couple Trans ams and refuse to drill holes in the noses for the stupid front plate. This is my first Camaro though and I'm using it for a daily driver. The thing is near showroom new looking and never had a front plate mounted. I had a fix it ticket for no front plate on one of the trans ams and didn't want to deal with that bullshit on the camaro.
Obligatory 15 year old photo from the last time I had an RS grill off a car.
Fwiw, I was able to get a collector plate here in Oregon as the car is 25+ years old, only required to have back plate, I've been doing this for many cars after moving here from Los Angeles 15 years ago. Don't know the rules where u r at, but I don't like a front plate,
i drove my trans ams for 20 years and never had an issue with no front plate until recently. Can you believe it,the cops out here charge $15 just to come out and verify the plate is on the car and sign off on the ticket
Yep, just hold it up in place and mark the holes. If you want to get fancy, I want to say there are reinforcements molded into the plastic where the screws thread in. If you pop the grill off the car, and look on the back side you might see them. However it's been a REALLY LONG TIME since I had a RS grill in my hands. I'm sure in most cases they were just held in place and power tooled to the grill.
Thanks very much Drew. That's the same grille I have on my 90 rs. This car is so clean even the power window buttons and door lock buttons have perfect yellow writing on them. Even the drivers side door has no sag! Just push it lightly and it latches. That's why I bought it. It was owned by an airline pilot since new and he rarely drove it.
i hate to drill into the grille. At least it's a part that can be replaced
Could always pick up an aftermarket grill and mount the plate to that and keep the original for a rainy day. Looks like the aftermarket grills have the holes marked. Seen a few stealth mount type setups with the plate mounted to a bracket that mounts under the front bumper.
Of course the best solution is to move to a non-commie state.
California is the real problem.
California is the real problem. Joined: Aug 2009
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Well, mine has never had a front plate mounted but I can feel where one must have been once. If you center the plate and slide the lower mounting block into the bottom slot on the grill then you may be able to feel where screws once were. Or now you know where they go...
Ah, Californication, don't you just love it?
stealtht/a
Exterior Parts for Sale
Mar 23, 2015 01:26 PM
