Repairing two "dings" in an otherwise beautiful hood
Old Sep 25, 2018 | 05:59 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I don't know what happened before I bought the car, but it looks like someone took the back of a ball pein hammer and hit the hood in two spots. The paint is otherwise exceptional around the car. I am hoping to find a shop that can repair just those two locations without a huge respray. I don't need it to look perfect, just really good. The two dings are on the outside of the faux hood vents. One on each side.
Old Sep 25, 2018 | 06:33 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Repairing two "dings" in an otherwise beautiful hood
Should be an easy fix from a PDR guy.
Old Sep 25, 2018 | 06:34 PM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
Do research on PDR in your area.. use someone that works on high end cars and show cars.. they use better techniques and can blend the dings making them invisible.. quick cheap PDR will still show the ding in certain angles..
A Porsche dealer would probably know a good guy.. People buy Porsches to keep..
A BMW would probably use a quickie guy because people get a new one every 2-3 years..
A body shop that does show cars would know someone as well as any high end detailers that work on rare and exotic cars. Some of those places do PDR as well..
Old Sep 25, 2018 | 06:35 PM
Axle/Gears: G80 GU2
It’s fixable for sure
Old Sep 25, 2018 | 11:13 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
I can't tell from the pictures if the paint is damaged or if its just dented. If theres no paint damage, what the previous posters said about finding a skilled paintless dent repair guy right. If the paint is messed up you'll have no choice but to respray the whole hood if you want it to look good. Theres really no way to avoid a 'huge respray', its all or nothing when it comes to paint.
Old Sep 26, 2018 | 08:06 AM
Engine: 350 TPI L98
Transmission: WC T5
Thanks all. I was encouraged until I read Zs's comment. I will get you all a close up but the paint is definitely gone at each spot and the edges of the surrounding hood paint can easily be seen and felt.
Old Sep 26, 2018 | 08:58 AM
Axle/Gears: G80 GU2
You might be able to buff out scratches.. I’ve gotten some out of dents with compound by hand and then after PDR it was invisible.
Sometimes something might look like a scratch or chip but it can be paint, finish or rub off from whatever hit the car and come right out..
If you end up wanting to paint the hood you won’t have to worry about PDR I guess.. hopefully not..
Old Sep 26, 2018 | 05:44 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
If it needs paint work, a paint shop can FOR SURE sand the entire hood, repair the dings, and only blend in basecoat (the red) where the repairs are, and then clear the entire hood. Then you won't have an issue of paint not matching. I'm a certified PPG painter, and can EASILY make that hood look like new with only blending color over the repaired areas.....but you won't have a choice about clearing the entire thing
You could give me that job on day one, and have it back on day 2. It'd probably be a $500 fix
Old Sep 26, 2018 | 06:26 PM
Axle/Gears: G80 GU2
Thats probably cheaper than a high end PDR guy..
Old Sep 26, 2018 | 07:45 PM
Engine: 350 TPI L98
Transmission: WC T5
That's awesome, thanks dagwood. That's in my price range for cleaning it up. I suppose as long the shop is mixing paint maybe fixing other locations on the car would be a good idea at that time as well?
Old Sep 27, 2018 | 08:00 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
If the hood needs any pant at all, there's no sense in getting PDR done. The whole point of Paintless Dent Removal is to remove dents without needing paint. If the paint is cracked, body shop it. Deep scratches? Body shop it. Deep dent? The metal is probably stretched and will need a body shop to fix, but get a PDR tech opinion before making that decision on your own.
Old Sep 27, 2018 | 08:03 PM
Axle/Gears: G80 GU2
Agree, you can never give real body advice with just pics..
Old Sep 27, 2018 | 08:04 PM
Axle/Gears: G80 GU2
dagwood's Avatar
Top Answer: 1
There are some times when we have our pdr guy do what he can with a ding to begin with to speed things up for us. He's at our shop every Tuesday anyways so it works out good for both of us..
InfernalVortex
Apr 30, 2012 11:28 AM
five7kid
Sep 27, 2009 08:51 AM
V8Rumble
Alternative Port EFI Intakes
Apr 15, 2007 08:41 PM
Chr1s46536
May 23, 2006 04:34 PM
BBCAM
Fabrication
21
Mar 23, 2006 12:30 AM
