How To Undercoating/Rust Prevention?
Old Feb 26, 2019 | 09:06 AM
BadPoncho's Avatar
Car: 1991 Z28
Axle/Gears: 12 Bolt Moser - 3.42 w/ TruTrac
Curious if anybody has any tips, tricks, or guides on how I can preserve this in its state. With the little rust it has I'd like to descale it and undercoat it but not sure how to go about it.
Old Feb 26, 2019 | 05:53 PM
DD9TransAmGTA's Avatar
Car: 1987 TA GTA, 1987 IROC 1988 Formula
Engine: 350 tpi/305 tpi/350 tbi
Transmission: All have 700r4's
Axle/Gears: 10 bolt with 3:73's
Re: How To Undercoating/Rust Prevention?
You'll want to strip the paint off anywhere you see rust bleeding through. Its probably gonna snowball by the looks of it so be prepared to spend some time under it with a angle grinder, etc. After you have most of the paint removed you can scrub it with a red scotchbrite pad and ospho. 2-3 coat should get it. Seal it up with primer and paint. Most suggest a epoxy primer and paint but I just recently used rustoleum self etch primer and their high performance enamel.
Old Feb 27, 2019 | 11:05 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Dry ice will help remove the under coating typically, never tried it on a third gen though. Just don't freeze burn your self.
Old Feb 28, 2019 | 09:17 AM
BadPoncho's Avatar
Car: 1991 Z28
Awesome! Appreciate the tips guys. I know on the main body it'll surprise you every time. Never done underbody work.
Dead Reckon
Feb 9, 2012 10:18 PM
Cratemaster
Nov 17, 2007 01:05 PM
Tricked-Out-Toy
May 25, 2005 11:56 AM
halloweenz28
Nov 14, 2003 12:04 PM
hotroc
Sep 21, 2001 08:53 AM
