T-Top bar, is there a difference depending on year?
Car: 1983 Pontiac Trans Am
Engine: 5.0 but about to upgrade.
Hi all, my T-Top bar is getting a little crusty so i'll either cut out the rot and weld it up or get a new one. I see the Stainless steel one has good reviews but it says its for 85-92 cars where as all the used oem ones on ebay say they are 82-92 cars.
Is there a difference between the earlier cars and the later ones? If so can it be easily modified to fit the earlier cars?
Thanks in advance.
Rob
Thanks in advance.
Rob
Car: 1989 Firebird
Engine: 5.7 LS1
Re: T-Top bar, is there a difference depending on year?
There are Factory T-Tops and there were a third party that installed them for GM. Make sure you have the fisher/factory T-tops. I'm not 100% positive if the 82-84 were the same, I would check with the vendor as to why they don't list it for the older bodies, by guess is it will work but would probably require a few tweaks.
Car: 1989 Firebird
Engine: 5.7 LS1
https://www.thirdgen.org/forums/body...et-t-tops.html
ahh the early t tops have arms that swing for the latch and the later ones pins, so its likely the t-tops center bar is different.
Thanks guys. Ive contacted Hawks to see whats what. I'll post my findings here for future reference.
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
I'm assuming you're asking because you want to keep and use your original removable tops?
Yes, I do enjoy taking them out for the 3 days of summer we get in the U.K. Ive heard back from Hawks, apparently the difference is the earlier t'tops have a metal edging where as the later ones do not making the earlier ones a little thicker. They say I could probably make it fit but for the cost of it and then fettling compared to repairing mine or getting a good secondhand one i think i'll repair mine for now.
The 85-92 cars did not have the plastic trim around the t top edge, therefore the t top bar is a little thinner to compensate for the thinner t top. It will work though.
Steven6282
Mar 23, 2012 02:19 AM
Nikole
19
May 18, 2005 10:35 PM
