Front bumper removal help
Old Jun 23, 2019 | 04:12 PM
Anderson84's Avatar
Car: 1984 Camaro Sport Coupe
Engine: SBC 355
Transmission: Turbo 350 w/shift kit
Axle/Gears: 10 bolt 3.55 gears, locker
I am removing my front bumper for paint but am having problems with the 2 studs that are in the headlight mounting bracket, they are stripped. Does anyone have some suggestions for getting the nut off to remove the bumper cover? Thanks.
Old Jun 24, 2019 | 10:32 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Re: Front bumper removal help
you may have to drill them out or grind the heads? Not sure what it looks like. WIll be taking of mine for paint in the next day or so.
Old Jun 25, 2019 | 11:33 AM
Anderson84's Avatar
Engine: SBC 355
Thank you, I was able to work the bumper over the washer on the stud after the stud pulled out if the headlight mount, will probably just drill it through now and put a bolt in
Old Jun 26, 2019 | 11:41 PM
Engine: 5.7
Axle/Gears: Stock
sure thing, I am running into this myself right now. I am removing my front bumper. 30 years of never being removed, HAHA, This will be fun!
Old Aug 22, 2019 | 05:18 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
im wanting to pull off the front and rear bumper covers off my gta parts car,any insight?
Old Aug 25, 2019 | 03:58 PM
83AQ9's Avatar
Car: 1983 Recaro T/A
Engine: GMPP 350HO Carbed
Yeah I have my rear bumper cover, actually the whole bumper too, off right now and it's easy.
Pop all the plastic push-rivets first. If your stud is stripped, my tip is "don't worry about it." Nuts are made harder than studs and bolts for just that reason. Wire brush the stud or wirewheel the stud with a dremel quick then blast that nuts off with the biggest powertool that fits.
punzak9
May 18, 2019 12:08 PM
senior bear
Jul 3, 2017 09:42 AM
1992rs/ss
Jan 4, 2017 12:56 PM
brian schuetta
Jan 3, 2008 07:09 PM
