question about rear deck and glass
Old Jun 26, 2019 | 11:40 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Ok so I am restore my bird. and I want to remove the rear glass. Mainly because I want to get into the areas around read windshield, gutters, to sand down and repaint. as well as get the metal bracket back on the glass on the top and paint it, which commonly pulled away.
Question, what is the best way to rest or store this glass while working on the back deck the body itself? I am so worried the glass may break while off the car. I noticed the rear deck can come off but it seams glued to the glass?
I also have to adjust the back deck being it has the pushed out issue so common on 3rd gens. Do I adjust the nuts on the glass side or roof side of the hings? AKA to push it all back in. If its on the glass side, what is the torque on the bolts? I am REALLY nervous about over tightening them and cracking the glass. Any experience with this would be very much appreciated. thanks!
Old Jun 27, 2019 | 12:28 AM
Drew's Avatar
Re: question about rear deck and glass
If at all possible, I'd unbolt the hinges from the body and leave all the hardware thru the glass alone. Otherwise you risk cracking the glass if overtightened. Also the round head bolts that retain the hinges to the glass, are only held while tightening the nuts by the hex shaft. Often they'll just spin when you try to torque the nuts.
Fairly sure the service manuals don't even list a torque spec. The impression I get is that GM didn't want dealership techs messing with the fasteners through the glass.
The trim, decklid, etc are all bonded to the glass. Getting the pieces apart can have mixed results.
I haven't inadvertently destroyed a hatch glass yet. There's some margin for error. But glass is glass, if you go a hair too far, you're SOL.
Old Jun 27, 2019 | 09:20 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
FWIW.........the hatch glass will not crack........it will explode
Old Jun 30, 2019 | 10:54 PM
Engine: 5.7
Axle/Gears: Stock
Well I abandoned removing the rear deck! So I want to paint the gutter around the window, and removing it seems to be the only option. As well as getting the metal wrap around back in place, sanding it down and paintig that. So how would i set it down without breaking the rear glass? thanks!
Old Jul 1, 2019 | 12:51 AM
Drew's Avatar
They will balance and rest well leaned up against a wall on end. Historically that's how I've stored hatches for years on end.
Old Jul 1, 2019 | 11:15 PM
Engine: 5.7
Axle/Gears: Stock
Thanks Drew. Very nerve racking to take it off and lean it up. Bad visions dance in my head, HAHA
Old Jul 8, 2019 | 10:11 PM
Engine: 5.7
Axle/Gears: Stock
Drew, check out this video, very helpful.
Old Jul 9, 2019 | 07:19 AM
Abubaca's Avatar
This is what I did during my paint project. There's no "official" adjustment via these bolts, but there is a little wiggle room front to back and I was able to realign my hatch during re-installation.
ray jr
Interior Parts Wanted
Apr 15, 2013 01:11 PM
FueledSoul
Jun 25, 2010 12:02 AM
JFeaster
Exterior Parts Wanted
Nov 8, 2007 07:06 PM
Pacer
Apr 22, 2007 07:10 AM
