Cheap weatherstripping solution?
Old Jul 13, 2019 | 12:25 PM
RandyNJ's Avatar
Is there any makeshift way to fix weatherstripping? Water is getting inside my doors when it rains and I don't currently have the money for weatherstripping. I don't have a garage either, so the car has to sit out in rain. The only solution I can think of is just covering the car with something for now.
Old Jul 13, 2019 | 07:08 PM
NoEmissions84TA's Avatar
Re: Cheap weatherstripping solution?
If the weatherstrip is collapsed in certain areas (and the door does not require adjustment), I have used the following trick. Go purchase some various sizes of windshield washer and vacuum tubing, and a tube of black RTV. Make a slit in your weatherstrip in a spot beyond the collapsed section and insert as much tubing as necessary to make the weatherstrip pop back out. Silicone spray will help it slide inside. When you get it where you want it and it seals, then just use a dab of RTV to seal up the slice you made. Good luck.
It might also be that your door hinge bushings are shot and letting the door sag. Fully open the door and grab the end opposite the hinges and see if the door moves up and down.
Old Jul 15, 2019 | 12:04 PM
RandyNJ's Avatar
Wonder if this would be any good? Reviews seem fine and someone even was saying they use it for car restoration.
Old Jul 15, 2019 | 06:21 PM
I doubt it. It needs to have the proper shape. Plus you will have to glue it in place. The method I suggested uses your original weatherstrip, which is still in place. Stuffing it just "pumps" it back up.
Old Jul 15, 2019 | 06:27 PM
RandyNJ's Avatar
It has self adhesive sticky stuff on the strip of it. Not sure how long it will last... It says it's weather proof and is even used for boats. Not sure how true any of that is. I just stuck it right on over the old weatherstripping. Regardless of how shitty it looks if it keeps water out that's all I wanted. I'll update on results after the next storm.
Old Jul 19, 2019 | 09:51 AM
RandyNJ's Avatar
Had a pretty large storm and water stayed out. The weatherstripping doesn't look the greatest and I'm not so sure how long it will stay on. In my opinion it's worth the $8 to keep water out.
Old Jul 20, 2019 | 09:31 PM
83AQ9's Avatar
Car: 1983 Recaro T/A
Engine: GMPP 350HO Carbed
Look for "The Right Stuff" gasket maker at the auto parts store. It's thicker than the regular RTV and a lot easier to handle when you are trying to make something a specific shape. It dries really fast and is nearly as strong as regular RTV on a clean surface.
ghettocruiser
Jan 25, 2017 09:06 PM
IROCZ28KevinZ
Convertibles
Oct 23, 2007 10:35 PM
seanof30306
Dec 12, 2005 08:32 PM
CrazyHawaiian
Apr 20, 2001 08:58 AM
burntblues
Feb 26, 2001 12:52 PM
