Easiest way to replace lug stud on driver side front?
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Hey all, back when I damaged my car, one of the driver side studs became a problem and I had to massacre it pretty good to get the wheel off. Whats the easiest way to fix or replace this stud
Thanks!
Thanks!
Car: '89 GTA
Engine: ZZ6TPI
Re: Easiest way to replace lug stud on driver side front?
Replace the rotor. They are cheap enough that it isn’t worth hassling with pressing out and pressing in a new stud.
Engine: 5.0
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
If the rotor is old, just replace it, otherwise you need to remove the rotor and use a press to push out the old stud and a new one in...
Car: '89 GTA
Engine: ZZ6TPI
Engine: 4++,350 & 305 CIs
Knock it out with a hammer and use a old nut and a couple washers to pull the new one through. Takes longer to jack up the car and pull the wheel than swap it out.
