Outer Door Sills
Old Jan 13, 2020 | 05:31 PM
ZackZ420's Avatar
Car: 1991 CamaroZ28
Axle/Gears: Stock
Outer Door Sills
Hello fellow Third Geners. I have the infamous sagging driver door. It has shaved grooves into the top of side skirt or as i call it the outer door sill. Have replaced pin and adjusted door. What can i do to repair sills or does anybody make Camaro Z28 sill plates that i can just stick over the grooves? Thanx
Old Jan 13, 2020 | 08:35 PM
jstadmud's Avatar
Car: 1987 IROC Z28
Engine: 5.0 liter
Transmission: 700R-4
Axle/Gears: 273 posi trac
Re: Outer Door Sills
I don't know what options are available for it, but I have the same problem on my '87 Iroc. I have the pins and stuff just haven't gotten around to fixing it. Not sure if there would be a proper fix for it short of body work and repaint
Old Jan 14, 2020 | 11:00 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Body filler and repaint is the option I would go with. If you are just looking to cover it up and look decent, you could do body filler and some type of decal. There isn't very much clearance between the bottom of the door ground effects and the rocker panel ground effects, so I would not want to add anything with any thickness to it.
91charlene
Apr 1, 2016 07:00 PM
pontiacdog
May 29, 2013 10:01 AM
aaronkark
Nov 8, 2002 08:43 PM
thatsme
Aug 22, 2001 10:45 PM
