Door latch and striker solutions
Old Oct 23, 2020 | 11:46 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Hey Guys -
rubber on my door latch has torn and no longer serving its purpose. door latch is banging against striker on bumps. weatherstrip is perfect condition and so is striker, looks like it came off the assembly line. door does not sag, and when it shuts it just sounds sweet. not an adjustment problem. it's gotta be lack of rubber on latch. windows are not rattling, the window stopper rubber has been replaced. this is a T-Top car, with windows down, Ttops off when this happens. I mean, is there any other way to drive it!
Anyone run across any after-market solutions, like a cover to fit onto the striker to make up for the lost latch rubber?
unfortunately, no aftermarket 89-92 door latches yet, that I know of
https://www.camarocentral.com/product_p/dwn-81.htm
Old Oct 23, 2020 | 12:11 PM
LiquidBlue's Avatar
Transmission: MD8
Re: Door latch and striker solutions
interesting idea
https://www.gmsquarebody.com/threads...ch-repair.624/
https://www.cjponyparts.com/door-lat...SABEgKOrfD_BwE
https://www.ebay.com/itm/Dorman-Door...-/302986426700
https://www.ebay.com/itm/Dorman-Prod....c100005.m1851
Old Oct 24, 2020 | 10:52 AM
LiquidBlue's Avatar
Transmission: MD8
I ordered the Doorman striker kit. its not intended for our cars, but the diameter is what we need. will let you know how it goes.
Old Oct 24, 2020 | 05:25 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I bought these for my 89 in 2017 and have had zero issues.
https://www.ebay.com/itm/DOOR-LATCHE...wAAOSwCFxeRM86
Old Oct 25, 2020 | 09:59 AM
LiquidBlue's Avatar
Transmission: MD8
great to hear! Here is a photo, they just arrived. note the pretty bevel
Old Oct 25, 2020 | 01:31 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Wont it make the bolt too thick for that latch? Is the plastic block in the latch still there? If its missing it can also cause rattles with latch/striker.
Old Oct 25, 2020 | 03:52 PM
LiquidBlue's Avatar
Transmission: MD8
yep,too big. latch wont go over it. which plastic block are you referring to, in the latch or on the door? i noticed the door is bouncing when I shut it, unlike the driver side, which does not.
Old Oct 25, 2020 | 03:58 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
In the latch.Striker slides on that and stops against it.
Old Oct 25, 2020 | 04:48 PM
LiquidBlue's Avatar
Transmission: MD8
thanks, i see. not sure if later model latches have those?? i was able to adjust the latch assembly up a millimeter or so, big improvement. Maybe it was an adjustment issue. wont know for sure until the next spin.
Old Oct 25, 2020 | 05:23 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
They all have them, unless they fall off,My 84 had them and so does my 89.
Old Nov 1, 2020 | 10:14 AM
LiquidBlue's Avatar
Transmission: MD8
I don't see them in mine. How do they mount? Not seeing anything in there for something like to mount. Not even sure if there is enough room in there for something like that to fit. How big are they?
Old Nov 1, 2020 | 06:33 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Not sure how the mount or how big. They're about next to the latch.Its what keeps the head of the striker snug.Here's a pic of mine, even my 84 had them
rcdreamer
Nov 2, 2020 11:34 AM
Bluestreek
Apr 1, 2016 02:03 PM
Ilike2stroke383
Sep 3, 2011 07:01 PM
sogabe
May 1, 2007 09:59 PM
