restoring front impact bar. need help
Old Jan 11, 2021 | 09:08 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
Im in the process of restoring a 89 turbo trans am. right now Im working on the front impact bar. I need info on the clips that hold the impact absorber to the impact bar. they are blue. are they original and are they still available? from what I can tell everything is original, so I would asume these are original as well.
Old Jan 12, 2021 | 02:35 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: restoring front impact bar. need help
NAPA Auto Parts has a big book with samples , you might find them there. Also, Auto Body Supply shops.
https://www.auveco.com/clips-fasteners I have bought clips from Auveco
Old Jan 12, 2021 | 05:53 AM
Alexcoqui's Avatar
Car: Trans Am "GTA"
Ive seen them in in black, bit was hoping to find some blue ones.
Old Jan 12, 2021 | 06:37 AM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
I work for gmc i used this part # 5973400
Old Jan 12, 2021 | 06:47 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I'm betting they were black. I've seen over time the black does turn to a blueish color on some of those type of clips.
Old Jan 23, 2021 | 09:38 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
https://www.clipsandfasteners.com/GM...h-p/a16265.htm
Old Jan 25, 2021 | 11:27 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Check your local parts store HELP/Dorman section.
They should have them there or can order them for you.
Old Jan 26, 2021 | 12:14 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
I bought them online. they are supposed to be gm correct part, but they are not identical. I used them cause they fit perfect.
here is a picture of the before and after of the fog lights.
1986z28custom
Jun 8, 2012 08:12 AM
Dubya
Mar 21, 2008 12:36 PM
89Iroc-ZL98
Mar 21, 2003 04:18 AM
