tail lights faded
Old Mar 16, 2021 | 06:55 PM
aussiesteve's Avatar
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
tail lights faded
can the lenses be removed from the light assembly..
i need to use that lens paint on the inside of the rear tail light lenses as there faded to allmost white,,
lights are still in great condition just faded..
how can i get the lenses removed
Old Mar 19, 2021 | 07:30 AM
Abubaca's Avatar
Re: tail lights faded
I've read that 200* in the oven will soften up the glue, then you can slowly and carefully start removing the lens. Never done it myself. Do a search for more.
Now that being said, I've restored several sets of tails and other plastic lights without removing the lens. I've found that if you take a good strong soapy water or simple green solution, fill the housing about a quarter full, slosh it around a bit and let it soak. Keep it cool so it does NOT dry. Give it about an hour, then repeat the process. Shake...rinse...shake rinse...until you feel they're pretty clean and you've got no more soap or cleaner in there. That'll do a pretty good job of cleaning out dirt, dust, bugs, gunk, etc. etc. Then do your standard sand/buff/polish to the outside of the lens like normal. I've used this method on some pretty ratty looking lights. Even though you can't FULLY clean and restore the inside this way, it'll still leave you with a 9 out of 10 quality resto.
Old Mar 19, 2021 | 09:58 AM
I have seen headlights put in a microwave then opened up....
my problem isnt cleaning the lenses ,,the lenses have faded in colour to near white in the orange part,,i have propper lens paint and its translucent orange.
this gets put on from the inside...
then the lenses put bacl on.
Old Mar 19, 2021 | 10:21 AM
the fix it link
Old Mar 22, 2021 | 05:37 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Or a heat gun will l also work.
Old Mar 22, 2021 | 07:33 PM
I saw on youtube,,no heat needed,, 4 plastic plugs come out and a few clips,, they fall apart and are simple to make new again.
C_Sander
Jun 30, 2011 02:04 PM
North
Mar 13, 2007 10:15 PM
Gr89RS
Jan 17, 2006 09:42 PM
91NiteRida'
Jan 9, 2005 12:01 PM
Paully92RS
Oct 21, 2002 08:27 PM
