Need help removing fender
Old Jan 30, 2022 | 01:24 PM
Vogue's Avatar
Car: 1989 Firebird
Engine: 2.8L V6
Transmission: Automatic
This bolt is on the bottom of the Driver Side fender (see pict).
It has three holes...tried a spanner wrench to no avail.
Any idea how to remove it?
Round bolt with 3 holes
Old Jan 30, 2022 | 02:15 PM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
Re: Need help removing fender
You’re looking at the nut, which is spot welded in place. The bolt head is on the opposite side. The bolt should be horizontal, it looks like the sheet metal is bent about 90 deg. Pry the flange straight again and you’ll have access.
Old Jan 30, 2022 | 05:32 PM
Vogue's Avatar
Car: 1989 Firebird
Engine: 2.8L V6
Thanks for your quick reply....I will look for the bolt!
Old Jan 30, 2022 | 08:39 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Yeah, that is bent, very typical sight. Just bend it down, 13mm for the bolt, i think.
Old Jan 31, 2022 | 06:01 AM
Vogue's Avatar
Car: 1989 Firebird
Engine: 2.8L V6
Thanks for both of your replies!
mr_blahblah3
Jun 21, 2009 12:26 AM
robster66
Dec 9, 2008 02:46 PM
Project_1986_TA
Dec 14, 2002 12:57 PM
87Bandit
Oct 23, 2002 06:11 AM
