T top edge
Old Aug 1, 2024 | 08:25 AM
KCG's Avatar
KCG
Car: 89 IROC
T top edge
Has anyone come up with a good sealer to use here where I drew the blue line? Something thin and UV resistant.
I have butyl rubber that would thin out and seal well but its just too soft and sticky.
Old Aug 1, 2024 | 08:32 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: T top edge
Was sealed to the glass when made. Tape off both sides and use windshield urethane in it. Not sure how UV proof it is tho
Old Aug 1, 2024 | 08:39 AM
KCG's Avatar
KCG
Car: 89 IROC
Re: T top edge
Yeah, I'm pretty sure this is where some of my leaks are coming from. Windshield urethane might be a good idea.
Something for a caulking gun would be great.
I'll check it out. Thanks!
Old Aug 1, 2024 | 12:34 PM
TTOP350's Avatar
Re: T top edge
Flip the ttop over and remove everything you can. You'll see how its sealed up.
you can use electrical tape over seams to check for leaks
Old Aug 1, 2024 | 01:50 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: T top edge
3m strip caulk
Old Aug 2, 2024 | 05:32 PM
KCG's Avatar
KCG
Car: 89 IROC
Re: T top edge
Originally Posted by midias
3m strip caulk
Looked at that but doesn't seem real promising for UV resistance.
3M 730 UV sounds like a winner.
Old Aug 5, 2024 | 10:42 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: T top edge
I put RTV in there a decade ago and it's still there.
Was one of my first attempts at closing up some of the leaks, though in hindsight I don't think this particular operation changed anything.
Old Aug 5, 2024 | 03:34 PM
sodak's Avatar
Car: 1985 iroc
Engine: 416 ls3
Transmission: t65
Axle/Gears: Ford 9"moser 31 spline 350 gears
Re: T top edge
Is this what your trying to do. They make replacement seals.
https://www.hemmings.com/stories/car...and-firebirds/
Old Aug 6, 2024 | 03:21 PM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: T top edge
That's the other side of the edge. He's looking at it from the glass side (from the car's center outwards) and the lip has no influence on that gap, sadly.
Old Aug 6, 2024 | 05:44 PM
sodak's Avatar
Car: 1985 iroc
Engine: 416 ls3
Transmission: t65
Re: T top edge
Ahhh got it .. Thanks
Yellowlt1
Aug 12, 2024 10:30 PM
88BLKTransAmGTA
Jul 29, 2023 02:55 PM
george88gta
May 12, 2023 03:49 PM
illuminati
May 15, 2018 07:56 AM
online170
Apr 9, 2007 08:07 PM
