lights
Old Jan 24, 2002 | 03:57 PM
PimpCamaroRS's Avatar
lights
i have tried to chang the guages in my dash twice alreay bt cn not seem to do it. i get the top of the dash off but then i am clue less...it looks like the entire dsh is connected. any one wanna tell me how to get to the bulbs behid my dash?"
Old Jan 25, 2002 | 04:01 AM
SilverChevy's Avatar
look where the light are for the check enige etc. their is bolts in their.
Old Jan 25, 2002 | 10:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Remove the black plastic bezel that covers the guages, and you'll see the two aforementioned nuts at the rear of the cluster. Drop the kick panel under the dash. Once it's removed, use a long flat-bladed screw driver to disengage the speedo cable which is attached to the rear of the cluster. Lowering the steering column a quarter of an inch or so will facilitate cluster removal. I would also advise covering the steering column with masking tape to avoid scratching. Once the cluster is out, you'll have easy access to the bulbs.
JamesC
Old Jan 25, 2002 | 12:19 PM
BitchinCamaro's Avatar
Damn, my methode for changing bulbs is a little easier I think. I took some needle nose pliers and wrapped the tips with masking tape for grip. It takes a little work, but I swaped all my bulbs, except the turn signals, with the cluster in place. This was on an '89 iroc.
Old Jan 25, 2002 | 12:31 PM
JamesC's Avatar
The method I mention appears to be complicated and time consuming, but, though I had never swapped out a cluster before, the whole business only took about an hour. With the cluster removed, you would, of course, also have the opportunity to swap in a 145 mph speedo as well new bulbs (xenon high-intensity bulbs are highly recommended). Removal also might facilitate mounting white-faced guages.
JamesC
Old Jan 25, 2002 | 04:03 PM
help guys my car is in pieces! the damn head light pully thin is not getting out of th way. how do i remove it!!!!!!
Old Jan 25, 2002 | 04:24 PM
Blue502's Avatar
You shouldn't have to touch the headlight switch to replace your gauges, assuming 82-89. I know nothing about 90-92.
To remove the headlight switch, turn your lites on, and push a button on the bottom of the switch. while pushing that down, pull out the ****.
Old Jan 25, 2002 | 05:10 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
You just gotta pull really hard.
Pull straight at yourself.
Don't worry, you wont break it.
It' is just got a notch that holds it there really well.
Old Jan 25, 2002 | 05:18 PM
Blue502's Avatar
Uh, yeah you can break it if you do it that way. That is why there is a button on the switch to release the ****.
Old Jan 25, 2002 | 05:45 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Not on the 90-92
Just Gotta Pull
Old Jan 27, 2002 | 02:30 PM
Blue502's Avatar
According to these guys, there is a release button on the '90-'92:
https://www.thirdgen.org/techbb2/sho...threadid=79841
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
