Window felt guides
Old May 25, 2025 | 01:34 PM
Sactodreamer's Avatar
Car: 84 Trans AM W62
Engine: 5.0
Window felt guides
I'm finally getting to installing all of the hardware/windows in the doors for my project. They're pretty much all done but I can't figure out where these felt guides go. I got the one on the right but I'm not sure about the one on the left with the hook.
Old May 27, 2025 | 12:01 AM
a1000wtp's Avatar
Re: Window felt guides
They go on the top of the of the door to stabilize the window. There will be two locations for bolts that they mate with.
You can see them in the photo below, just above where the arrows are pointed.
https://www.idmsvcs.com/2vmod/thirdg...dowtracks2.jpg
Old May 27, 2025 | 12:09 AM
Engine: 5.0
So both of the ones in the picture are just two different versions of the same thing?
Old May 27, 2025 | 01:38 PM
a1000wtp's Avatar
They should be the same ones (the one on the left in your photo). I'm not sure where the other one would go...
Old May 27, 2025 | 01:57 PM
Engine: 5.0
I'm guessing different years then. I put these on where they came off on a camaro from the wrecking yard.
Old May 29, 2025 | 01:12 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The style on the LEFT was used until around 89-90 or so and the one on the RIGHT was used in the 89(?) + cars.
You can use the 'late' style on earlier cars if you have too, but can't use the "early' style on later cars because of the other parts involved. The white plastic hardware mounted to the door glass has "hooks" on it during the later years and those "hooks" fit into the slot on the guides to better hold the window firmly in place. The window 'up-stop' was also changed at the same time. ( The 88 'up-stop' was shown upside down in that pic by mistake ! )
MentalEntropy
Sep 23, 2022 03:58 PM
N_da_Mood
Sep 4, 2012 02:37 PM
jpearsall187
Aug 1, 2010 11:57 AM
Chevy8588
Jun 24, 2009 04:06 PM
ontogenesis
Feb 28, 2003 11:41 PM
