Firebird headlamp gaps
Old Aug 14, 2025 | 09:18 PM
steve40's Avatar
Putting the car back together after years
What is the typical gap size between the headlamp and hood/fender?
Does the front of the lamp line up with the front of the fender?
Old Aug 15, 2025 | 10:37 AM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: Firebird headlamp gaps
its like 3/15 to a 1/4 all the way around. you ant really fully align them until the bumper is on
--also what year do you have?
Old Aug 15, 2025 | 01:15 PM
steve40's Avatar
87
I have the bumping hanging on the fenders and plate in front of the rad.
Old Aug 15, 2025 | 03:14 PM
OrangeBird's Avatar
Car: 1989 Firebird
I got them to this point, and then gave up on chasing exact gaps all the way around. In person the difference in the passenger's side door gap isn't quite as obvious as it is in this pic
Old Aug 15, 2025 | 04:25 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
those are far enough off on both sides it would bug me
Old Aug 15, 2025 | 05:13 PM
OrangeBird's Avatar
Car: 1989 Firebird
What I ran into was if I moved them any more backward (toward the windshield) they hit the hood while opening. If i attempted to fix that by moving the hood backward to give room to move the doors backward, the gap between the hood and nose became huge. So, I chalked it up to; #1, I do believe it had been hit in the front at least once, and, #2 it ain't a concourse restoration of a showcar, just a fun daily driver.
......Got any pics of your's
Old Aug 16, 2025 | 10:25 AM
steve40's Avatar
Yea just working on the second lamp.... Bumper is loose still
Anyone one find a place to buy these?
Old Aug 18, 2025 | 02:47 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
http://www.clipsandfasteners.com/?Click=2
https://www.clipsandfasteners.com/Fe...pas1601-15.htm
Old Aug 18, 2025 | 04:40 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
this was last year before i took off the front end to start the color change.
Old Aug 18, 2025 | 04:42 PM
gbeaird's Avatar
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
Are the doors level with the hood? From the angle of the picture, it would seem if you could raise the leading edge of them a bit that would take care of a lot of that offset. But yeah, if you're dealing with aftermarket replacement parts, the fit is going to be 'ok' at best.
Old Aug 18, 2025 | 04:49 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
The problem is the gaps all compound off each other. The doors dictate the rear fender gaps. Then you line up the front bumper and hood. Headlights are last because they have infinite adjustment but I can’t seem to get them perfect either. It’s kind of get it close enough and leave it alone. There’s too many adjustment points and most of them are a real PITA with the front bumper / ground effect and core support infill piece installed.
Old Aug 20, 2025 | 11:51 AM
gbeaird's Avatar
Axle/Gears: 9" 3.73
Originally Posted by battmann
<SNIP>
It’s kind of get it close enough and leave it alone. <SNIP>
IIRC, that's what GM was going for when building these cars!!
And yeah, I know one adjustment begets another, and they tell two friends, and so on, and so on... Never-ending project, usually. Hood closes, doors latch, you're golden!!
Colt
May 5, 2014 03:10 PM
