How do I replace t-bar??
Old Jan 26, 2002 | 01:47 PM
90CamaroRSGuy16's Avatar
I have t-tops and my current t-bar is rusted. What do I need to do to put a new one in?? thanks...
Old Jan 26, 2002 | 05:06 PM
mckenzie's Avatar
i think you have to remove the t-top weatherstrip, and then remove the screws. :rockon: best of luck, tom
Old Jan 27, 2002 | 11:40 PM
360Iroc's Avatar
thats it its easy
Old Jan 28, 2002 | 08:31 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Removing the black center piece is easy if your replacing your weather strip, BUT if your not, its a pain, because the weather strip is glued in..
By the way, there are usually some screws under the weather strip OTHER than the 6 or so that you can see.
John
Old Jan 28, 2002 | 10:11 AM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
when you put the new piece in make sure that you seal underneath it or else you'll have a leak. Use some weatherstrip caulking (like a whole tube of it) to seal the piece and then do the same with the screws when you put them back in...
Mike
Old Jan 28, 2002 | 10:27 AM
okfoz's Avatar
there were actually holes in my unibody, so definatly a good idea to seal all that up, or it will leak on your back seat...
John
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
