145 speedo and white face gauge idea
Old Feb 19, 2002 | 09:41 AM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
Tell me if this will work.
I changed the speedo drive and driven for a rear end swap recently. After doing the math on an excel spreadsheet so I could see and compare all gear combinations, I wondered if it would be possible to swap the gauge face from my stock 110 to a 145 then swap the drive and driven gear so the new ratio would drive the 110 speedo to a real speed of 145.
The speedo would be the same but with the cover displaying speeds to a higher rate, I figured it would be a cheap swap.
I think this would also disable VSS. When I went form 2.73 to 3.42, the speed limiter would kick in at 110 on the speedo but I had a friend clocking me at 89.
What do you think?
Thanks in advance,
GCore
Old Feb 19, 2002 | 10:06 AM
un4givin89's Avatar
No it will not work, you need to replace the whole gauge itself, this question has been answered many times on the board. You must replace the whole speedo, no need to rip out the whole cluster, just the speedo, and replace it with a 145mph speedo.
Old Feb 19, 2002 | 06:54 PM
SlowCamaro88SC's Avatar
and it's as easy as Mike said.
take out 110 speedo, not the face, the whole thing. Plug in 145 speedo, fin.
that's it. a good and easy "mod" if you call it that.
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
