how do you fix a sagging door?
Old Mar 3, 2002 | 10:13 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
my friend got this 81 camaro last friday and one thing we noticed was that the doors sag.........now i told him what we did in my bro's 73 nova to fix it but he doesnt believe that is the safest and right way to do it......my friend doesnt want me to lead you guys on to thinking the way we did it was right......so i was wondering if i could just get your opinions and then i will say how we did it...............and also.....would he just b able to get a new hinge and it would b fixed?
Old Mar 4, 2002 | 04:20 AM
sbd4de3's Avatar
Its not actually the hinges that go bad it is the pins that hold the hinges. Go to www.3rdgensolutions.com and get the set I ordered last week. Or you can go to autozone and get the help,me pins but you will have to replace those every few years or so!
Hope this helps you and your bud!
Steve D in Hawaii
Old Mar 4, 2002 | 05:12 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Actuall, 2nd gen F body hinges are completely different than 3rdgen hinges. You can actually fix and or replace both hinges very easily. They are not welded to the door like 3rdgen hinges are.
As far as I know they are still available from GM, or Classic Industries.
Thanx,ANDYZ28
Old Mar 4, 2002 | 09:05 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
ok well thats not what we did.....but if it works then that is cool........what we did was we jacked up the car by the door and bent the hinge back up.......my bro said he heard somewhere that u can do this and it wont harm anything......and it didnt.....the doors shut fine now
but thanks
i think he will do that
oh......2nd gen camaros and firebirds have the same kind of door hinge dont they?
Old Mar 5, 2002 | 05:12 AM
ANDYZ28's Avatar
Car: 1982 Z-28
That is kinda like putting fix-a-flat in a tire. It's OK for a short while.
The second gen hinges are not stamped like 3rdgen hinges. They are cast. How you are going to bend a cast hinge I don't know. I believe that the door itself will actually bend first. Or maybe even the body. I certainly do not recommend this procedure!
Thanx,ANDYZ28
Old Mar 5, 2002 | 03:05 PM
JAF's Avatar
JAF
NAPA, AutoZone, and other parts stores have replacement bushings which will solve the problem. The only difficulty is realigning the doors on the hinges (you'll need help). I've replaced these on 2nd gens by myself and it is a hassle.
Even now that you've bent your hinges back, those bushings still need replacing. Hopefully you haven't damaged the doors or hinges. If you have, contact YearOne or your local junk-yard if it is a beater.
Old Mar 5, 2002 | 06:16 PM
camaro6spd's Avatar
yep for thirdgens ANDYZ28 has a monopoly on hindge repair kits that are insainly priced with outlandish materials. Why not just a castle nut?, nylon locking, two nuts up agaisn each other? Aerospace 12 pinot nut, BHAA!! WTF needs that? I am working on getting a lath(spelling?) and making some cheapers ones $125 dollars for 4 pins and bolts? WTF
Old Mar 5, 2002 | 08:28 PM
ANDYZ28's Avatar
Car: 1982 Z-28
OK! I have noticed that over the past few months "camaro6spd" has had an issue with the price of my UPPER door hinge pin&bushing kits. So "camaro6spd" what price should I charge? $5.00 maybe $10.00?
Old Mar 5, 2002 | 08:36 PM
Coxy's Avatar
Car: 91 RS B4C
Engine: 355
Transmission: TH 350
Andy, I think your products are a great thing, but you could sell a lot more if the price was a little lower. Man I program & setup Okuma CNC lathes and I know you can make at least 20 of them an hour.
Old Mar 5, 2002 | 08:54 PM
ANDYZ28's Avatar
Car: 1982 Z-28
I don't have any Okuma CNC lathes! I must get someone else to do it.
Apparently the price is not an issue for a great many people. As I am still just barely able to keep up with the orders. No kidding.
Old Mar 5, 2002 | 09:22 PM
Coxy's Avatar
Car: 91 RS B4C
Engine: 355
Andy, find a source with CNC, you will save a bunch and be able to pass the savings on to your customers and to me in the near future also
Old Mar 5, 2002 | 09:37 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
ok well he does plan on changing out the pins and bushings......my bro did change the pins and bushings in his car too......
sounds like you guys are on your own subject now....so i will let ya go on with that
thanks
Old Mar 6, 2002 | 09:27 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Yanking the door up is nothing more than a medieval door adjustment which can be performed more permanently by loosening the hinges and actually adjusting them.
The doors on third gen cars are long and heavy and wear the hinge/bushing components very easily. Myself, I would just order new hinges.
Old Mar 6, 2002 | 09:43 PM
ANDYZ28's Avatar
Car: 1982 Z-28
"Myself, I would just order new hinges." Changing the hinges, which are welded to the door is a real pain.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
SG91camaro
Sep 5, 2015 10:27 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
