whats wrong here??
Old Mar 13, 2002 | 10:44 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
whats wrong here?? (arm rest problem)
OK, for some strange odd reason caused by some unseen force of nature, the inner part of my arm rests are folding out!! I can't push them back in, and it is very uncomfortable to rest your arms on them. So anyone got any ideas on this? these aren't very good pics, but im gonna try to get better ones, so work w/ me plz
Car: 89 Camaro RS
Engine: 2.8L V-6
another pic of it....
Old Mar 13, 2002 | 10:51 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Aw yes, the glue holding the vinyl to the inner part of the armrest has worn out and will continue to peel. You can fix that by taking them off and putting new glue inbetween the two, then get two 2x4s and a C-clamp,put the blocks on each side and clamp it down and let set for a day or so.
Old Aug 26, 2002 | 06:20 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
I finally got around to pullin them off, but I don't know what kind of glue to use. Any suggestions?
Old Aug 26, 2002 | 07:57 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
any regular epoxy, theres also a tech article on this
Old Aug 26, 2002 | 08:08 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
There's a tech article? I didn't even think bout that, I'm so used to just askin, lol. Will liquid nails work?
Old Aug 26, 2002 | 08:34 PM
89Irocz23's Avatar
When I had that problem with my old interior I used this exposy stuff at advance auto. I had to mix to tubes of stuff together. I forget what kind it was but it worked fine until I sold all my red interior ans bought black interior.
Old Aug 26, 2002 | 09:06 PM
BAK12484's Avatar
i tried using some contact cement that you brush on...worked good for about a month or so, but then it started to come apart...could be because the stuff was so old tho.
I suggest using some type of epoxy, as they are usually the strongest
Old Aug 26, 2002 | 10:19 PM
FLYNLOW92rs's Avatar
Yup there is
Old Aug 26, 2002 | 11:15 PM
logikal6785's Avatar
here you go
https://www.thirdgen.org/newdesign/tech/armrest.shtml
Old Aug 27, 2002 | 12:30 AM
jawzforlife1's Avatar
dont use liquid nails, that is for woor. you plastic epoxy, should gome in 2 tubes that you mix together.
Old Aug 27, 2002 | 04:15 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
I've started gluin them together, got a 2 part apoxy, but I only have 3 clamps, and I borrowed those from school, so it could take a while. I'll get pics when im done.
Old Aug 28, 2002 | 12:09 AM
HrdRockA4305's Avatar
I'm starting to get that as well.....
~paying attention to what everyone said to do and thinking about it~
(not to mention taking the opp. to post ***** )
Old Aug 28, 2002 | 12:20 AM
Archael's Avatar
hey quick question about your sig. what exactly are tubular t top holders??? the bag is all i know about ...i've installed my amp and 2 12's and i'm lookin for an alternate holding method for my tops..thanks
CrazyHawaiian's Avatar
Car: too many ...
that happened to me too ... tried to fix it but it happened again ... finally gave up and bought a set of black ones off ebay for $20 and they've been good for a year now.
Old Aug 28, 2002 | 10:05 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I think originally the armrests were molded, and as they age they seem to shrink, thats why its pulling away... Glue should help some tho, not sure for how long.
When my center console started to seperate, I first used rubber cement, it did not hold overnight, so i removed that, and use superglue, been like that since 1997, and still holding. I had to clean all the stuff off of it but its done.
John
Old Aug 28, 2002 | 09:02 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
Got them done, they look decent, but they had both shrunken enuf that they didnt fit right around the edges so I did the best I could. They look better than before though, and are even more comfortable cuz my arm isn't resting on that corner part. So im pleased, for now, until I can buy some perfect ones off ebay.
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
