How do you replace these...........
Old Mar 21, 2002 | 11:37 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I need to replace the window rails on my car. Do you need to pull the door panel and remove the glass? Here's a pic of what i'm talking about. I highlighted the part .
Old Mar 21, 2002 | 11:41 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
i'm curious too, mine are cracked...you are talking about the rubberish pieces right?
Old Mar 21, 2002 | 11:53 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
You'll need to remove the door panel, but not the glass. They're held on by a bunch of screws. Make sure you have a magnetic screwdriver or drive socket for putting them back on, othersie it gets a little frustrating dropping screws.
Old Mar 21, 2002 | 03:28 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Yeah I tried to do this the other day. The outer piece is screwed to the door with about 8 to 10 screws, the inner piece is stapled to the black molding that runs the length of the door. Now the black molding piece is held on the door panel via little thin type of nut, I dont know how to take these off without breaking the plastic or ripping the cardboard like door panel, which is what I did, damnit. Taking the whole door panel off with the black molding left on is probably the safest way to do it, then you could replace the rubber strips and assemble it back together.
Since my car is a 86, everything whether its rubber, plastic, or whatever is extremely brittle and worn out, so I'm learning the hard way to do things.
Oh one other thing, my window was in the way of the two middle screws that hold the outter strip to the door. I do not know how to get around this yet, I saving that problem till I actualy get some new rubber strips to put on, then I will figure that one out.
Hope this helps to let you know whats involved in doing this.
Any thing else, feel free to ask.
Old Mar 21, 2002 | 03:37 PM
ebby53's Avatar
Check out the Tech Article on the home page.....All about windows and door panals......
Old Mar 21, 2002 | 04:22 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Thanks for the help guys
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
