interior question
Old Mar 24, 2002 | 07:43 PM
Halberto45's Avatar
interior question
my mom just bought me a 91 Rs camero but i can't find out how too set my favorite rap stations can you guys help me? or should i post in the proformance section? why do they make these electronicos so confusing?? in my humble opinion its wacked! :lala:
Old Mar 24, 2002 | 07:50 PM
Jza's Avatar
Jza
To set the station preset on your CamAro, you change to the channel you want to preset with the channel ****, then press SET, then the desired preset button. If you think that's confusing, then I pity you.
Old Mar 24, 2002 | 08:22 PM
Halberto45's Avatar
:hail: :hail: :hail: :hail: :hail: :hail: :hail: :hail: :hail: :hail:
WOW it worked I never knew it was that easy, man my system is bumping!!!
THANK YOU SO MUCH, I swear all this jap electronics confuses the **** out of me. I do have a hard time learnin and you should pity me I have a learnig disability and ADD so bear with me if you can i am going to have alot of question when I start modding this thing out!
thanks guy you have made my life alot more livable!
Old Mar 24, 2002 | 10:03 PM
Halberto45's Avatar
damn it I disconected the battery when I wanted to change some of my stations so I wouldn't get shocked and I lost all of my stations, is there any way too get them back? does it help if I have lojack?:lala: :lala: :lala:
you will be a *** if you answer my quesiton:hail: :hail:
Old Mar 24, 2002 | 10:45 PM
PopaPork's Avatar
Are you for real dude? If you are, there is no way to get the stations back on a stock radio with out putting them like you just did by holding down the SET button. But you said your system was "bumping" and I know nothing stock bumps, are you sure you dont have Aftermarket? I dont think the lojack matters at all. Just put the battery cable on, and leave it on. Just a warning if you are joking and making stupid post, I urge you to leave, poeple dont take kindly to it. But if your for real, ask away, you will get top notoch answers here. Good luck with the car
Old Mar 24, 2002 | 11:03 PM
5.0L1992RS's Avatar
Are you serious. Did you actually think that buy changing some of you stations that you would get shocked??? BTW, are you even old enough to drive, becuase if you are, you should realize that by changing radio stations, you can NOT get shocked.
Halberto45's Avatar
Ahhh this blows I had like 27 ****in stations on that radio set are you sure there is no way to get them back like some sort of memory switch that will bring them back? I have lojack if that matter and It was my understanding that with lojack it moniters your car and knows the speed what stations you listen too and where your car is. PLEASE I REALLY SPENT SOME TIME ON MY STATIONS IF ANYONE KNOWS A WAY REPLY OR EMAIL ME!!!
Old Mar 24, 2002 | 11:09 PM
Tonyrodz's Avatar
Transmission: auto
can't you tell when someone is screwing w/you?
Listen--you'll get your radio stations back if you punch it a few times--always worked for the other guy!
Old Mar 24, 2002 | 11:20 PM
89transam's Avatar
I heard if you take teh radio out of the car and put it in water all of the most recent deleted settings come back.
It has something to do with "shocking" the unit into the old ECM mode, where it recalls the last flux settings (radio presets). I heard a bathtub works, but to get everything perfect i hear the ocean is great because the salt water interacts with the diods and changes the logic gates (previously NAND ) , to Nor.
I dont beleive it though
Nate
Old Mar 24, 2002 | 11:49 PM
Twistopher's Avatar
Car: 91 Z28 Convertible
Engine: 305TPI
no what you do is you go over to the battery and hang on to both terminal. What happens is it redownloads all the stations back into the radio. Sort of a battery backup system.
Old Mar 25, 2002 | 01:38 AM
Kevs86TA's Avatar
Car: 86 Trans AM
Sounds like you need to call GM and talk to one of the engineers maybe theey can help.
Old Mar 25, 2002 | 03:41 AM
bjm323's Avatar
Car: '91 Camaro RS
The correct way to do it is disconnect the #1 spark plug wire. You hold it while someone else turns the motor over. This should surge the flux capassitor and reset the radio stations.
Old Mar 25, 2002 | 12:27 PM
89camaroRSV6's Avatar
NO.... he should take the radio out of the car and take it to the doctor...maybe its sick
lol
is this guy for real
Old Mar 25, 2002 | 08:08 PM
Twistopher's Avatar
Engine: 305TPI
no... notice the banned under his name... i read through his 30 something posts. someone just spoofing
Old Mar 25, 2002 | 09:41 PM
89transam's Avatar
Radio Fulid is low?
nate
Old Mar 25, 2002 | 10:49 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Well, the first problem is that he listens to rap...
Old Mar 26, 2002 | 01:18 AM
383 Smoka's Avatar
JESUS CHRIST GUYS! Im crying here!!!!!!! *** damn u guys are howls... Its 2:15 am and I cant stop laughing... Every post on this thread just kept getting better.... ****, thats howls... WOOOOO!
Old Mar 26, 2002 | 09:50 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Sorry, I can't help you restore the radio station presets. You forgot to use the "Permanent Save" mode. First step is to set the stations as previously described. Next you pull very hard on each button use a pair of pliers to get a good grip. You will hear a nice comforting snap as each button is removed. Cover the holes where the buttons were with a piece of electrical tape.
Old Mar 26, 2002 | 10:25 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
this guy must be a import guy screwing around on the board.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
