Mystery or Mystic Teal ?
Subscribe
Mar 29, 2002 | 04:35 PM
Can anyone clarify the following code for me?
WA-L9238 U9238 82C
I believe it to be the paint code for the color Mystic Teal,
can anyone tell me is this the whole code, part of it, or what.
Or is it for something else, the code was found in the drivers side compartment inside the trunk.
many thanks
Reply 0
Mar 29, 2002 | 05:36 PM
Reply 0
Mar 29, 2002 | 06:22 PM
Thanks 82RECAROTA, you have saved me a lot of wondering,I can now order up the right paint .
Thanks!!
Skunk
Reply 0
Mar 30, 2002 | 02:50 AM
What do you use to decipher the paint code?
Reply 0
Mar 30, 2002 | 07:37 PM
Reply 0
Mar 19, 2012 | 12:53 AM
Re: Mystery or Mystic Teal ?
Hi - what was the answer? Was it mystic teal please - I have the same code on my Camaro here in Aust - WAL9238 U9238 82C
- Best regards, Ron Mc
Reply 0
Mar 19, 2012 | 06:49 AM
Code is WA-9238. As I recall, 82C should reference it as well. Is this what you're looking for?
http://paintref.com/cgi-bin/colorcod...?gmcode=WA9238
http://www.paintscratch.com/touch_up...37-WA9238.html
*Edit-It appears 82C is the interior spec. Nevertheless WA-L9238 is the "lower" color and WA-U9238 is the "upper" color. Same code, same color.
Reply 0
Mar 19, 2012 | 07:01 AM
Found this pretty cool little gadget. Go here and put in GM and your year. If you select Chevrolet it'll only let you select from years lower than '78. See if you can find your WA number below the color on the chip sheet.
Reply 0
Mar 19, 2012 | 09:45 AM
Quote: Found this pretty cool little gadget. Go here and put in GM and your year. If you select Chevrolet it'll only let you select from years lower than '78. See if you can find your WA number below the color on the chip sheet.
Pick "GM" and you can then pick the right year.
Reply 0
Subscribe
