Trying to Find 1" Bore MC
Old Jun 1, 2005 | 09:39 PM
colonboy14's Avatar
Car: Trans Am
I am trying to reduce the pedal travel and increase it's feel by going to the J65 MC that had the 1" bore. However, I just went to NAPA and bought a MC for an 86 disc/disc car (which should be J65) and they gave me the same MC I have now, with 18006814 cast in the bottom. Where can I get the real J65 MC?
Old Jun 1, 2005 | 11:25 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Oooh, ooh, what is the difference in master cylinder sizes?
I was under the impression that the MC was the same on all of these cars and only the prop valve was difference on a few of them.
Old Jun 2, 2005 | 08:53 AM
colonboy14's Avatar
Car: Trans Am
No, the J65 master which came on disc/disc cars up to 89 had a 1" bore. The J50, which came on all disc/drum and all cars 90-92 has a 15/16" bore.
Old Dec 30, 2006 | 01:29 AM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Sorry for bringing this back from the death. I realize most say to use the J50 with the 1LE valve with the 1LE setup front and rear.
My 89 has the rear PBRs and I am going with Ed's C4 setup in the front and am going to change the valve to the correct 1LE 14089496.
Regarding the MC what exactly would the 1/16 difference between the bore sizes do ?
I understand the J65 I have has a 1 inch bore and the J50 ( rear drum ) MC has a 15/16 bore. Thx for any replies.
Old Dec 30, 2006 | 02:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A larger bore increases pedal effort and reduces pedal travel.
Old Dec 30, 2006 | 08:59 PM
Jetmeck's Avatar
That being the case I don't see why I should should
change to the smaller bore of the J50. I have read multiple times it is the MC used with the 1LE setup.
Old Jan 3, 2007 | 02:34 PM
Jetmeck's Avatar
So the final word on this is......there isn't much if any difference between the two ?
Old Jan 3, 2007 | 03:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Pretty much. GM even put out a TSB telling dealers to change one for the other if the customer didn't like the pedal feel.
Old Jan 3, 2007 | 03:28 PM
Jetmeck's Avatar
Thx
Old Jan 3, 2007 | 03:29 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
exactly.
the fluid displacement vs pedal travel is almost identical.
you will get a larger pedal diff depending on how soft the bottom of your sneaker is.... lol.
angel2794
Sep 8, 2015 06:22 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
Strick1
Sep 4, 2015 07:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
NinjaNife
Aug 23, 2015 11:49 AM
