how big of a job to replace all break lines?
Old Nov 15, 2003 | 07:26 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
ive got a leaking wheel cylinder in the back left and a major leak up front so im going to replace all the break lines threw out the car all the way up to the master cylinder cause i want it to last i will be doing it on a lift so that is not an issue what am i getting my self into? my car right now has to be taken to the lift by trailer cause i literaly dont have any breaks whats so ever.
Old Nov 15, 2003 | 08:21 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
i'd say it's a pretty big job, maybe not so hard if you use braided lines, but a pain in the *** if your having teo bend hard line....but i consider most things a pain in the ***...
Old Nov 15, 2003 | 08:36 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
it will be just like doin fuel lines a 4 hr job at least
Old Nov 15, 2003 | 08:42 PM
ede's Avatar
ede
big pain in the *** job, but not hard to do and on a lift would be a piece of cake
Old Nov 15, 2003 | 08:56 PM
z28monster's Avatar
Car: 86 IROC-Z
good
yeah ill have help also i wont be alone and il have alot of tools to use 4 hours is not bad to be at all. atleast i will no it will last
Old Nov 15, 2003 | 10:00 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Good luck with the front lines, they go underneath the motor and along the crossmember. Kind of hard to get to unless the motor's out. The back ones aren't too bad though, fairly easy to get at.
Old Nov 16, 2003 | 02:32 AM
joshwilson3's Avatar
Old Nov 16, 2003 | 02:54 AM
kfoley's Avatar
Car: '85 Z28
There's a place that has pre-bent lines for resto stuff. I can't remember their name, but they advertise in the back of CHP and the other big car mags. I don't have one handy, but I'll post it up tomorrow.
Old Nov 16, 2003 | 11:10 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
Classic Industries has a front to rear hard line for our cars in both standard and a stainless steel. $50 for the standard - $70 for the SS IIRC. Pre-bent with the right adapters on it - definately worth the money to save the hassle IMO. dunno about the fronts - don't see it on their page
Old Nov 17, 2003 | 12:01 AM
Old Nov 17, 2003 | 12:26 AM
kfoley's Avatar
Car: '85 Z28
Percy's makes some braided stainless lines. They're kind of pricy, but they'll last a long time and they shorten your stopping distance. You can get them from summit.
Old Nov 17, 2003 | 02:24 AM
Old Nov 17, 2003 | 01:07 PM
kfoley's Avatar
Car: '85 Z28
Sorry, they're Earl's, not Percy's. P/n is EAR-28A180 for front discs, EAR-28A190 for 4 wheel discs. Buying the bulk line is definitely cheaper, however it will be time consuming making all the bends, but if you have a lift and some help it shouldn't be too bad.
Old Nov 18, 2003 | 06:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
http://www.classictube.com also sells them. Biggest "pain" will be the front-to-rear brake line; you'll have to move some brackets and yank the crossmember (I think) to get the line out. I swapped it out when I went to rear discs. (The '84 prop valve I used took the rear line from the "front" of the valve, as opposed to my '86 line which took the rear port from the "bottom" of the valve- so I put a front-to-rear line into my car from an '84 f-body.)
Old Nov 18, 2003 | 06:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Originally posted by joshwilson3
I was at summit and I saw that they sell bulk brake/fuel stainless steal hard line fairly cheap.
You'll also need to flare the ends; 84-up used metric ISO "bubble flares". That basically means a more expensive tool; and you'll need to find the fittings. (I couldn't find them locally; but wound up finding them on pre-flared sections of brake line at Pep Boys. Paid $5 a line to get two fittings.) Look to places like http://www.toolparadise.com or similar for an ISO bubble flaring tool. Eastwoodcompany.com also has one.
Old Nov 18, 2003 | 06:28 PM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
I just replaced all my lines with the kit from Classic and put on Goodridge Lines to finsih it off.
The lines were next to perfect, just some minor bending to get them exact.
My engine is not in the car so it made the job easier.
Old Nov 18, 2003 | 08:25 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
double flare not bubble
Old Nov 18, 2003 | 10:43 PM
Thirtybird's Avatar
no, he was correct - 6mm line with a bubble flare fitting on each end.
You find ISO bubble flares on metric lines
You find double flares on SAE sized lines
I recently went through the nightmare of locating proper brake line for my 1991 Z.
Old Mar 15, 2004 | 08:45 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
you can get a set of already bent lines from www.inlinetube.com... save yourself ALOT of work and they are all stainless steel, factory bent lines...
cstrobel65
Aug 15, 2015 10:19 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Leggman1
Aug 6, 2015 04:15 AM
