Some new brake goodies
Old Aug 27, 2004 | 07:43 PM
Spdfrk1990's Avatar
Notice the ceramix 1LE pads, also bought new rear loaded raybestos calipers a few weeks ago.
Old Aug 28, 2004 | 12:35 AM
firehawkslplus's Avatar
Car: 91 Firebird Dark Green
Engine: 350 Victor Jr. 2V 2000 CFM TB EFI
Transmission: 700R4 BM 2500 stall
Axle/Gears: 3.73 Zexel torque sensing Posi
Re: New brake goodes
I just wanted to let you know that the CMX pads that NAPA sells ARE NOT perfomance pads. I work for NAPA and remmber when the pads came out. There was a little blurb about there being ultra low dusting and low noise (designed to vibrater at higher frequency). This was later brought home when one of the taxi companies and the Leon Valley police complaned of short life and fading (police). A better choice would be the AE or if real hard on the brakes SD (Sever Duty). Not meaning to rain on your parade.
Old Aug 28, 2004 | 06:22 AM
Spdfrk1990's Avatar
Yes I know i use to work at napa also , Im not gonne be road racing them or nething.
Old Aug 28, 2004 | 06:34 AM
Spdfrk1990's Avatar
If i wanted to go with a good performance pad tho and didnt want the AE who makes the best. Does hawks make a 1le pad.
Old Aug 28, 2004 | 11:23 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Buy Stillen pads, You'll thank me later. Hawks are so-so. Stillens are designed for maximum street use without compromising any noise problems at all, and are very rotor friendly. They will not groove the rotors because the material is softer than the rotor, very low dust. I ran down in a pinch a few weeks back and Stillen was temp out of my front truck barke pads (I have run them on this truck for years) so I opted to try out some of these famous "Performance Friction Pads" that everyone around here raves about. The frikin truck doesn't stop with them- they are terrible. I ran down last week to pick up a couple more sets of Stillen pads to have on hand- They last me about 1 year on this heavy vehicle that I carry very heavy loads in always (so believe me, I know about brake fade.)
Old Aug 28, 2004 | 11:50 AM
Spdfrk1990's Avatar
Where can i get stillen pads for the 1LE.
Old Aug 28, 2004 | 12:14 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Just so you know, When looking for any 1LE pad, the GM configuration is D412. Non-1LE pads are configuration D154.
You'll want Stillen Part # D412HD
http://www.stillen.com/brakepros_det...id=8846&page=1
Old Aug 28, 2004 | 03:23 PM
Spdfrk1990's Avatar
Thanx man would that be the best place to get them. Also do you know if they get much squeek or if they come with shims?
Old Aug 28, 2004 | 11:51 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Don't know about shims. I have never owned a 1LE setup. (Have driven many with though.)
Old Aug 29, 2004 | 09:47 AM
Spdfrk1990's Avatar
I think i will buy them next pay check with my Braided lines. I returned the ceramix and got some silicone brake fluid and some money back.
Old Sep 28, 2004 | 12:24 PM
Spdfrk1990's Avatar
I just ordered the stillen pads they better be good for 101.37 with shipping
Old Sep 28, 2004 | 12:56 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Please do everyone a favor- After breaking them in poperly(give them a little time just like any pad) get on them and test em hard for fade, dust, pedal feel, initial bite
and please then give imput. I think everyone needs to hear another opinion on them other than myself.
Old Sep 28, 2004 | 01:06 PM
Spdfrk1990's Avatar
I will how many miles u think i should go b4 break in 500? Well maybe not that many maybe 300
Old Sep 28, 2004 | 01:14 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
As long as the rotors are seasoned (have been heat cycled and ran with any other pad aready) They will seat easily within 100 miles.
If the rotors are still new, worry about breaking them in before worrying about the time it takes to seat the pads. (More like 500miles of heat ups and cooldown trips- not one continual 500 mile drive.)
Old Sep 28, 2004 | 01:16 PM
Spdfrk1990's Avatar
Rotors r brand new pictured above still in boxes
Old Sep 28, 2004 | 01:18 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
If the rotors are still new, worry about breaking them in before worrying about the time it takes to seat the pads. (More like 500miles of Normal driving heat ups and cooldown trips- not one continual 500 mile drive. And try to avoid any hard or panic stops if all possible in that time frame)
Soory, I was still editing the above and adding the duration
Old Sep 28, 2004 | 01:26 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
One thing I do to any pad I get (If not already done) is grind the leading edge to a 45* to reduce or eliminate noise and to smooth out the initial bite of the pad even more for predictability. Doesn't have to be pefect 45*, just do quickly by hand with a grinder.
Old Sep 28, 2004 | 01:31 PM
Spdfrk1990's Avatar
Doesnt stillen do that the ceramix pads i bought and took back had that alrdy done. That was one reason i got them. Yes like you said i hope its alrdy done specially for the price.
Old Sep 28, 2004 | 02:46 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
The Stillen pads I run on my truck rears do. I run Munstang SVO calipers back there and Linclon rotors.
The smaller d154 Stillen pads I have bought many times over the years for the stocl Camaro iron calipers don't. I just quicly tapper them myself.
Its not a big issue to do this yourself. Reason why alot won't come pretappered is because it takes away surface volume of the pad contact patch onto the rotor. they leve it to the owners decression as to what they want to do to them. These are about the max friction level pad you'd want to run for everyday street use. Any race pad WILL make noise when used on lower everyday street temps. These are marginal, so aplications will, some won't. Rears generally make more noise than fronts because they induce lighter pressure. Pad noise of this type is only from light pedal pressure. If they aren't tappered, a sander with 60grit paper will do it even.
Old Oct 4, 2004 | 03:39 PM
Spdfrk1990's Avatar
Just got the pads today they are champfered on the edges look nice ill maybe get some pictures later.
dbrochard
Sep 19, 2015 08:13 PM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
