Rotors? Left or right?
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Does it matter which rotor goes on which side? I need to replace my right front rotor, but I have a left instead (with no reciept = no return). Will it matter if I put it on that side rather than its intended side? I broke off two studs and I need to replace them before my wheel falls off
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: Rotors? Left or right?
Car: 1992 Firebird
Engine: forged 357
Re: Re: Rotors? Left or right?
Originally posted by THEGENERAL
wont matter if you are replacing them with one side or the other on a stock replacement rotor...they are exact same part numbers and have no designated side....
thanks a lot for your fast reply man :hail:
dont believe everything autozone tells you ..LOL..they are computer mechanics ...they only know what the computer screen tells them most of the time....not that im knocking people that work at autozone but alot of people that work their dont know what a rotor looks like much less how to install one..
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
Originally posted by Apeiron
Why not just replace the studs instead of the whole rotor?
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
If it is a drilled or slotted rotor then then the people who made it can have directional vanes inside the rotor so that would make a difference. Not too likely but it can make a difference.
I thought all rotors had directional veins... that would be how it pulls air through the middle and out the edges, after all, right?
I would replace just the studs or do a complete brake job... rotors, pads & bearings on both sides.
Car: '88 Formula
Nope, our factory rotors have straight vanes so they can be used on either side. High performance rotors are typically curved and will flow more air because of it, I'm sure there are some cars that come that way.
thats why i said in my first statement if your replacing with a stock replacement rotor its okay to use it on either side....
if they are aftermarket and slotted and drilled that is a different story ...
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Yeah my drilled/slotted rotors can only be installed on the side they are designed for. Straight vanes I believe, but its the holes and slots that are on an angle that's directional (like directional tires
) Joined: Jan 2000
Car: '88 Formula
A hole in a rotor is just like any other hole in a rotor, it is the vanes that do the work of moving air. As far as I can tell they make left and right rotors like that for looks only, so both patterns face the towards the rear of the car. I am basing this of the fact that the vanes are straight.
blackandblue02
Sep 10, 2015 08:19 PM
