Spindle Modifications
Old Dec 8, 2004 | 05:57 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
For the front brake conversions that need a bracket added to the spindle - has anyone done these w/out removing the spindles from the car??
Old Dec 8, 2004 | 06:30 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I know some guys but I do them removed. The thing is that you really need to drill the holes in very straight for proper thread engagement after you tap them.
Ed
Old Jan 5, 2005 | 05:33 PM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
I did mine with the spindles still attached and it was very easy. The trick is to drill the holes by sneaking up to the final size. By using the smallest drill bit that will actually remove any material the drill bit will self align itself in the hole and its almost impossible to drill it off center or at an angle. Worked for me.
Old Jan 5, 2005 | 08:03 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Good point.
I saw one where the guy just drilled the lower hole right through and used a bolt with a nut on the other side because it would be stronger than the tapped threads. Easier to safety wire it that way too.
Old Jan 6, 2005 | 12:47 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
That's actually not a bad idea at all. Would there be any downsides to just drilling through and using a nut on the back side? Maybe a possibility of being a bit off-set from where it needs to be?
Old Jan 6, 2005 | 08:30 AM
ebmiller88's Avatar
I've thought about doing it this way but I like the idea of having the bolt threaded into the spindle as well just to have more thread engagement. You can do it but I like the tapped spindle with the bolt on the back idea. Overkill maybe, a dab of Locktite does the same thing.
Ed
Old Jan 6, 2005 | 09:27 AM
Purple 92 SS's Avatar
Car: 1992 Z/28, 2000 SS, 1968 RS/SS
Engine: 355 Built a bit / LS1
Transmission: T-5 / A4
Axle/Gears: 4.10 / 2/73's
Ed,
You dont happen to sell the LS1 Spindle / kit
do you?
If so pm Me about it! Im intersted.
-steve
Old Jan 6, 2005 | 09:44 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
I like the "seaking up" approach too if you are gonna drill them on the car. Makes perfect common sense. Nice tip Norwood Nice new bits might be a worthy investment also.
Old Jan 6, 2005 | 02:05 PM
Car: 1997 Corvette
Originally posted by Purple 92 SS
Ed,
do you?
-steve
Of course he does! I've been talking to him about a C4HD setup.
Ghettobird52
Apr 21, 2020 08:44 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
jdperformance
Sep 16, 2015 11:55 AM
rb85TA
26
Sep 14, 2015 10:29 PM
