LS1 rear brakes.. should I go for them
Old Dec 25, 2004 | 10:26 PM
VILeninDM's Avatar
Hey guys,
I just came across a relatively cheap set of rear brakes from LS1 car. My rear end is from 96 car.
Should I buy these, or wait till I find LT1 set?
I did some searching and there are various opinions. Some said new holes (8 total) need to be drilled and then I found 88IROCARMY's thread that said they will bolt on to the housing if you use LS1 backing plates.
Sme people staying away from them, and others said they converted and could be happier. So those that converted, what is actually involved in this?
Old Dec 26, 2004 | 12:18 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you have the backing plates, rotors, calipers, then you are good to go.
If you have a drum rear, then I have no idea what is involved since I never messed with drums.
If I remember correctly, LS1 and LT1 backing plates are different and don't interchange due to the different style of e-brakes.
Old Dec 26, 2004 | 12:30 AM
VILeninDM's Avatar
cool, they are sold with everything including the backing plates.
So then the only question is that e-brake bracket that has to be fabbed. Does anyone have a picture of it preferably off and on the car?
Old Dec 26, 2004 | 11:44 AM
Zepher's Avatar
are you talking about the bracket on the rear that holds the ebrake cable? If so, that is interchangable on the rear since it uses the lower control arm bolt to hold it in.
Old Dec 26, 2004 | 02:44 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
No, the bracket that connects the hand-brake-lever cable to the two cables that go to each drum in the back. I have to get some new brake cables cuz my uncle threw out the first set I got, and then I have to make a custom bracket.
Old Dec 26, 2004 | 05:08 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You mean this one:
Old Dec 26, 2004 | 06:57 PM
VILeninDM's Avatar
Don, I give you full credit for trying to help but that is the smallest picture of any bracket I've ever seen.
Otherwise, I am not sure what bracket I am talking about. I just read several ebmiller's posts where he mentioned some bracket for e-brake needs to be fabricated making LS1 brake install more complicated than LT1 brake install. Now I just want to find out what exactly needs to be done.
Old Dec 26, 2004 | 10:20 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
I believe the axles have to be changed when going from LS1 rears to LT1 rears. Something about different lengths do to the different parking brake setup. Minor difference, but it does cause problems. Check some 4th gen sites to verify.
Kevin D.
Old Dec 26, 2004 | 11:06 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
not true.
i just followed the tech article on mine. somebody told me the stock ebrake cables from a late disc model thirdgen will fit if the end is enlarged a little bit to fit the ls1 lever. i bought some, but the opposite end is different from the y cable thats on my car, and ive been too lazy to find the right one
Old Dec 26, 2004 | 11:19 PM
shr00m's Avatar
So you had an LT1 disc rear and swapped it over to an LS1 disc setup no problem?
Kevin D.
Old Dec 27, 2004 | 12:01 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i had the stock drum rear, reused the axles, just cut and drilled the housing end accordingly and bolted everything up. i did have the parking brake hooked up, but it was ghetto (involving some braided cable using wire clamps) and it did work, but it was def unsafe so i took it off
Old Dec 29, 2004 | 12:37 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Def worth it putting on LS1 brakes. They have a thicker rotor and better ebrake.
I think theres a bigger picture posted somewhere of that bracket. Do a search for LS1 brakes and Dyno Don.
Old Dec 29, 2004 | 12:42 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Lokar universal cable kit and my custom fitment.
Old Dec 29, 2004 | 12:48 AM
Car: 1997 Corvette
Nice, how much did that cost ya, and how much modifying did ya have to do?
Old Dec 29, 2004 | 01:05 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Very simple. The bracket came with the Steelbraided Lokar universal kit. It was aprox $100 for cables, brackets and clevis'es.
I then drilled through the cable connection block (center hole) to a large enough hole so the factory threaded cable end fit through it. I cut off shorter the factory cable and reinstalled the nut onto it.... whaa-laa- Clean and simple.
Old Jan 2, 2005 | 07:10 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
That's "viola", Dean....
Ed
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
