lt1 brakes
Old Jan 6, 2005 | 05:10 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
lt1 brakes
Will lt1 front brakes fit under the stock 15" wheel? I'm thinking of doing an lt1 brake swap all the way around if they fit.
Old Jan 6, 2005 | 09:32 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
They're just like the ones on your car so why install them?
Ed
Old Jan 6, 2005 | 09:50 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
No..they are like the 1LE setup, aren't they? If you don't have the 1LE setup, it may not be a bad idea if you can get everything for free, do the work yourself, and have a goal of fitting them under a 15" rim.
Old Jan 7, 2005 | 05:09 AM
ebmiller88's Avatar
He did say "LT1 fronts", not the rears and he didn't say LS1 so that tells me he wants the single piston LT1 brakes. And they aren't like 1LEs....
Ed
Old Jan 7, 2005 | 10:07 AM
z28z34man's Avatar
I thought ls1 where bigger and had no chance of fitting under a 15" wheel. I all ready have the lt1 calipers. I don't have 1le brakes.
Old Jan 7, 2005 | 07:48 PM
ebmiller88's Avatar
They won't bolt right in on your spindles so you'll have to to some fab work to even get them on. And they're very similar to the single piston brakes you have now so IMO it's not really worth it.
Ed
Old Jan 8, 2005 | 12:25 AM
Car: 1997 Corvette
Ed
Ah, wasn't aware. I had thought the front LT1s were similar to the 1LEs, but now that you say that, I know you're right. I knew the LT1s were single piston and the 1LEs were dual piston
Jump up to 16" rims and get some LS1, C4, or C4HD brakes, or jump to 17" rims and get the C5 brakes.
Old Jan 8, 2005 | 10:05 AM
z28z34man's Avatar
The thing is I don’t have the money for bigger rims and I hope to be trapping at 110 ish this spring and I don’t know if the drums are up for that. How about lt1 rears for now and when I get the money c5 rims and front brakes would that get the job done.
Old May 29, 2005 | 10:04 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Is there a difference between the 3rd gen and lt1 style rear discs, besides the cables?
Do 15" wheels fit on the lt1 rear discs?
Old May 30, 2005 | 06:28 AM
ebmiller88's Avatar
Not really, just the e-brake cables and bracket. Some 15"s will fit, some won't...it will depend on backspacing and offset.
Ed
dbrochard
Oct 3, 2015 12:43 PM
New2Chevy
Sep 28, 2015 12:35 AM
L0tuS
Sep 4, 2015 11:16 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
