LT1 rear disc
Old May 11, 2005 | 04:52 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
LT1 rear disc
will swapping over a LT1 rear disc setup (rotors, PBR calipers, backing plates, ebrake cables, etc) bolt right upto my '88 iroc rear end? If not, what mods will need to be done?
Also, what does PBR stand for? Thanks!
Old May 11, 2005 | 04:57 AM
Brisk's Avatar
oh ya.. I've got a stock 10-bolt rear on my car currently.., plus I'd need to ensure that the stock 16" rims would still fit.
Old May 11, 2005 | 10:37 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
10 bolt with 16" wheels...yes, bolt right on.
Ed
PS: PBR:
http://www.pbr.com.au/about/recognition.shtml
Old May 11, 2005 | 02:10 PM
Brisk's Avatar
Thanks Ed. Which brake lines would I need to purchase (part number?), or would a mechanic just fab some up? Also would you happen to have a correct proportional valve I could purchase? (from a 89-92 I think?)
Thanks for answering my questions. I thought PBR was a material or metal blend, not a brand name.. duh!
Old May 11, 2005 | 02:14 PM
ebmiller88's Avatar
If you need just the rear lines, let me know. You can't just buy rear sets, you'd have to get the whole front and rear set, and I have 2 sets of just rear lines on hand. Of course, they're Earl's lines, best out there. You won't need different axle lines so I won't address those.
I have 2 early 1LE prop valves that will fit your '88, also new. LMK...e-mail me or PM.
Ed
Old May 12, 2005 | 05:03 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
4th gen ebrake cables most likely won't work since the retaining clips on the body are at different locations.
Old May 29, 2005 | 09:53 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
So an 1LE prop valve will be correct for a 93 LT1 rear disc setup? I've seen the ones by Wildwood and Summit, but if there is one that is preset, and works correctly, then I would prefer that.
Would the 93 master cylinder bolt right up too? It looks better then the old style our cars have.
I have seen what Zepher is talking about, they go into a bracket that sets differently than our cars. But it looks like if you just save the cables on that bracket that ties them together, you might be able to just attatch that to the adjustment slider for our cars.
Old May 30, 2005 | 06:29 AM
ebmiller88's Avatar
Yes...LT1 calipers are the same as 1LE calipers essentially.
Ed
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
