Ford Focus brake fluid?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
well i went to the ford dealership (stealership) this afternoon and got ford brake fluid... from last time i looked it up, i recall the ford HD stuff as one of the better choices...
well i just looked at the can i got... its "ford focus only" DOT4 brake fluid.. and it says not for DOT3 systems.
now i know DOT3 and DOT4 to be compatible... DOT5 is silicone and NOT compatible...
but im just curious, did i just spend $20 on the wrong brake fluid?
im flushing the whole system out, and installing braided SS flex lines, a line lock, and adjustible prop valve...
before i go fill/flush my system with this, is it the right stuff?
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Dot 4 is fine. What is the Wet and Dry boiling point? That is the important part. DOT 4 typically has a higher Wet Boiling point that DOT 3.
Here's some excellant info:
http://stoptech.com/whitepapers/brakefluid1a.htm
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I'll toss this in here for reference....
Dry Boiling Point Wet Boiling Point Viscosity @ -40°C Viscosity @ 100°C
DOT 2 374°F N/A
DOT 3 401°F 284°F
DOT 4 446°F 311°F 1800 max 1.5 min
DOT 5 (silicone) 500°F 356°F
DOT 5.1 (non - silicone) 500°F 356°F
Castrol LMA DOT 3/4 446°F 311°F N/A N/A
Ford Heavy Duty DOT 3 550°F 290°F N/A N/A
ATE Super Blue Racing 536°F 392°F N/A N/A
ATE TYP 200 536°F 392°F N/A N/A
Motul Racing RBF 600 593°F 420°F N/A N/A
Motul DOT 5.1 N/A 365°F N/A N/A
Motul DOT 4 473°F 316°F N/A N/A
Motul DOT 3 462°F N/A N/A N/A
Prospeed GS610 610°F 421°F 1525 2.5
Castrol SRF 590°F 518°F N/A N/A
Performance Friction 550°F 284°F N/A N/A
AP551 527°F 302°F N/A N/A
AP600
(not DOT approved and not compatible with any other fluids)
572°F 410°F N/A N/A
Ferodo DOT 4 446°F 311°F N/A N/A
Ferodo DOT 5.1 500°F 356°F N/A N/A
Wilwood 570 570°F N/A N/A N/A
Valvoline Synthetic DOT4 502°F 343°F
If you get the boiling points of Ford HD DOT4, we can add it in that list.
DOT 2 374°F N/A
DOT 3 401°F 284°F
AP600
572°F 410°F N/A N/A
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
I use all Motul fluids in my mountain bikes, customer bikes and my car. I work for a dealer so its cheaper than the store stuff.
Car: 1990 Camaro RS
If it wasn't so expensive I'd run Castrol SRF.
For me, pricepoint, and ease of getting it. ATE gets my money.
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
I run Valvoline Synthetic DOT4. You can get it just about anywhere so its easily axcessable, its fairly inexpensive, its compatable with all DOT3 & 4 fluilds so you can mix it, and it has a dry 502* and a wet 343* boiling points.
Night rider327
Sep 2, 2015 04:17 AM
