PBR e brake adjustment help
Old Feb 16, 2005 | 07:27 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
How do you adjust the e brake/parking brake on a car with PBR rear discs? The car in question is a 90 Formula and it has a swapped in 9 bolt with the PBR brakes. My car came with drums originally and has no adjustment on the cables as did the older Moraine equipped cars. I read about an adjuster screw on the caliper itself and a procedure somewhere but I can't recall where. Does anyone here know this procedure?
Old Feb 16, 2005 | 07:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Might run a search on Ed Miller and Trickster (if I recall correctly, I saw info in their links). I swapped in PBR's on my 85 IROC with no difficulties. I, of course, have provision to adjust the parking brake in the tunnel. I set the free travel screws (I think that's what they were called) according to the manual, and all works great. Got curious myself. Check the following link:
https://www.thirdgen.org/techbb2/sho...and+adjustment
JamesC
Old Feb 18, 2005 | 10:58 AM
Mongoose's Avatar
Car: 90 Formula
Thanks for the info James. The park brake is working but I would feel more comfortable if I could have a little more travel in the handle when I apply them than what I have now which isn't much but it still works. I plan to get that solved when I swap in this 4th gen e brake handle to compliment the rest of the 4th gen stuff I've swapped in recently.
Old Feb 20, 2005 | 02:17 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hi Mike...you don't have the adjusting screw mechanism in the trans tunnel?
Ed
Old Feb 21, 2005 | 03:38 PM
Mongoose's Avatar
Car: 90 Formula
Nope,never had it. I'm guessing that since the drum rear cars had adjusters at the wheels there was no need for one in the tunnel. I'm hoping to get them adjusted this weekend if I can find a spare set of hands as this procedure looks like it would take two people to do it right. Would it be possible to transplant that tnnel adjuster into the car if I could find one?
Old Feb 21, 2005 | 06:53 PM
ebmiller88's Avatar
Yes, that's what I'd suggest actually. IIRC, none of the '90-up cars had the adjuster, only the older cars had them.
Ed
Old Feb 22, 2005 | 07:53 AM
Mongoose's Avatar
Car: 90 Formula
Ed, I just looked over the post JamesC gave a link to earlier and I saw the pics of the caliper you posted showing the adjustment screw. Would I have to turn the screw in or out to get more movement in the brake handle? I'd like to avoid trying to swap the tunnel adjuster if at all possible.
Old Feb 22, 2005 | 09:43 AM
JamesC's Avatar
Another link:
https://www.thirdgen.org/techbb2/sho...free+%2Btravel
JamesC
Old Feb 22, 2005 | 10:27 AM
ebmiller88's Avatar
The small set screw will do nothing for lever control. All that little thing does is set your piston angle to adtjust the parallel face of the pads. I've never had to mess with it really but it won't help your situation. Your issue has to do with overall cable length.
Ed
Old Feb 23, 2005 | 03:18 PM
Mongoose's Avatar
Car: 90 Formula
After reading that link that James put up it looks like it would be the fix for the problem. I'm using the correct cables for the PBR calipers so maybe there is a different cable that goes from the lever to the junction that meets the other two cables for disc brakes cars? If so anyone know a part number?
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
