No Back Brakes!!!!
Old Mar 8, 2005 | 08:02 PM
DJMAD127's Avatar
Car: 87' pontiac formula
Engine: 350 tpi
Transmission: auto
No Back Brakes!!!!
N
Hey 3rd gen members,
i had a question about a brake problem........i am a 19 yr old pontiac nut and so is my dad. i have a 1987 pontiac formula 350 tpi with disk brakes all around. I went to get my emmisions test and the back brakes would not stop the rollers and i failed that time. I told my dad and he said thats how the factory brake are set up so only 5% of the brakes are from the back brakes....i dont think thats the way there set up. I tried bleeding the brakes and also changed the calipers with a set from autozone. This did not help at all....rear brakes still suck....i also heard many thing about my year pontiac rear brakes "Freeze" but can find a way to fix them. Also heard it has something to do with the E-Brake. Any advise would help alot. thanx
Old Mar 9, 2005 | 07:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yep, that's the way they are from the factory. This thread contains a fix for them:
https://www.thirdgen.org/techbb2/sho...hreadid=279615
There is also a recall kit that can be fit to the rear calipers. Problem with that is that replacement calipers don't alway's have it either (as per the auotzones you received). May have to do with the cost, the kits aren't cheap. A search here should bring something up on it.
RBob.
{edit: a few more good threads with additional information and alternatives:
https://www.thirdgen.org/techbb2/sho...threadid=78725
https://www.thirdgen.org/techbb2/sho...hreadid=127100
Old Mar 9, 2005 | 09:25 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you can't stop the rears on the drum because you have no rear brakes at all, it's not a proportioning valve issue so don't worry about that yet. Try the recall kit first:
https://www.thirdgen.org/techbb2/sho...ht=%2B18019028
sailtexas186548
Jan 19, 2016 12:21 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
