9 bolt brake question??????
Old Mar 9, 2005 | 07:47 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
Is there a differance between the 89 pbr disc brake set up and the 88 9bolt setup with cast iron crap calipers, as far as the rotor thickness is concerend? Any info would be great.
Old Mar 9, 2005 | 09:24 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Rotor thickness? No..they're both .81" thick.
Ed
Old Mar 13, 2005 | 08:16 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
1989 pbr brakes---Pictures don't work anymore.
Old Mar 17, 2005 | 10:03 PM
zombie-z's Avatar
Car: 1998 ss
Engine: ls1
Transmission: t56
If your using the pbr's, its cheaper and easier to find 93up camaro rotors.They bolt right up. I got em on my junkyard 9-bolt with pbr's.
Old Mar 18, 2005 | 12:31 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
you mean rear disc brakes from 93+ camaros are cheaper and just teh same thing? for any pbr application whether its the 9bolt or 10bolts of 91-92?
Old Mar 18, 2005 | 06:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yep.
JamesC
Old Mar 27, 2005 | 12:34 PM
cocacolakidd's Avatar
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
9 Bolt Brake
If the Rotors are the same (1LE 11.65" Rotors) - Third Gen to Fourth Gen...The question is; are the PBR aluminum calipers the same, or will they mount to the 9 bolt backing plate? Thanks, Ed.
Old Mar 27, 2005 | 12:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
PBRs use different backing plates. This is a good thing, since 88 9-bolt disc backing plates can be pretty hard to find.
Old Mar 27, 2005 | 01:20 PM
JamesC's Avatar
PBR's 89-97 are pretty much the same and will bolt to 9- or 10-bolt backing plates. Check the following link for info that may be helpful:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
Old Mar 27, 2005 | 09:52 PM
ebmiller88's Avatar
There's a slight difference in the way the 4th gen and 3rd gen plates are made but they are essentially the same.
Ed
Old Mar 28, 2005 | 01:35 AM
Car: 84Z & Porsche
9 Bolt Brake question
I have the 1LE rear brakes on a 1989 9Bolt rear axle assembly (Installed in my 1984 Z), and I'm going to rebuild the rear calipers, replace the discs, and pads. I have assumed that the 9 bolt was from a 1989 IROC with the 1LE optional brakes. The calipers are PBR Aluminum, and the discs are 11.65”dia. So with this in mind if I get rebuild parts for the calipers for a 1989 IROC to 1997 Z28 rear caliper, this should work?
I have found through Parts America a rebuild kit for the rear calipers, p/n D352746...I will take the caliper in with me to check to see if this is the correct p/n on a correct kit.
Does any body know of an all inclusive kit to rebuild these calipers? (correct kit and correct p/n) Should the piston be replaced at the same time?
Thanks, Ed.
Old Mar 28, 2005 | 06:48 AM
ebmiller88's Avatar
All '89-97 rear disc cars got "1LE" brakes. All rear PBR calipers from '89-97 will use the same rebuild kit, and yes it's all inclusive. You won't need to replace the piston unless it's damaged, sticks, or is corroded. Those are available separately.
Auto Zone, Brakeware kit #60196, around $12.
Ed
Old Mar 28, 2005 | 08:11 AM
Car: 84Z & Porsche
( bolt Brake question
Thanks Ed, I can go with that kit.
Ed.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
redmaroz
Aug 16, 2015 11:40 PM
